hphan1229's avatar
hphan1229
Guest network not working on the RBR50 + RBW30 mesh system and 2.4Ghz network issue.
I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months.  I've upgraded to the firmware version 2.5.1.8.  I have couple IOT devices (Nest Yale X Lock, Nest thermostat) that only connect to the 2.4Ghz and every couple days, they go offline so I have to reboot the Orbi system couple times to get the devices to be online again.
Another issue that I have since day 1 was that the Guest Network never works.  I can connect to it but couldn't get to the internet.
Anyone having the same issues?  And suggestions?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • hphan1229's avatar
      hphan1229
      SURFBoard SB6183
      3300 sqft
      30-40 ft
      I've tried channel 1, 6, and 11 on 2.4Ghz and 48 on 5ghz
      I can detect about 6 other wifi SIDs from the neighbors.
      Done this but no helps.
      Not yet.
      • FURRYe38's avatar
        Try a factory reset, I believe this corrected another users problem with Guest Network not working on theres a while back.
        hphan1229 wrote:
        SURFBoard SB6183
        3300 sqft
        30-40 ft
        Not yet.
  • CrimpOn's avatar
    CrimpOn
    I assume you know they have gone offline because the smartphone app reports it cannot reach them?
    When this happens, does the Orbi show them connected?
    Since these devices are sort of "permanent", I would assign them a specific IP address in the Advanced Tab, Setup, LAN Setup screen.  Do they have assigned IP's?
    When a device connectes to the guest network, does the Orbi "Attached Devices" show it connected to "Guest"?
    • pravinvekaria's avatar
      pravinvekaria
      Regarding the Guest Network, i have the same issue. I have multiple models of Satellites, the one that is causing the issue for Guest WiFi is the RBW30, disconnect that from the power and your guest network will start working! With it connected and if your device has roamed onto that Satelitte then your guest will get an IP address and everything will look fine but you wont be able to get any Internet Access or ping any internal (which is expected on guest) or external (which should work) IP addresses.
  • FURRYe38's avatar
    Any progress on this?
      hphan1229
      It's been busy so I have not had time to deal with this but this problem still persists.  Now, I am also experiencing another problem that no devices can access the wifi once every couple days until I reboot the router.  I have not dealt with the Guest network either.
  • I had the Orbi mesh system that includes the RBR50 router and 2 satellite RBW30 about 2 months.  I've upgraded to the firmware version 2.5.1.8.  I have couple IOT devices (Nest Yale X Lock, Nest thermostat) that only connect to the 2.4Ghz and every couple days, they go offline so I have to reboot the Orbi system couple times to get the devices to be online again.
    Another issue that I have since day 1 was that the Guest Network never works. aboutpetguide  I can connect to it but couldn't get to the internet.
    I am having the same issue, did you resolve it.
    • CrimpOn's avatar
      CrimpOn
      You may have noticed that the two posts in February about problems with the Guest network have never been followed up.  It appears to me that the people who started this discussion are no longer participating.
      My sense is that you are more likely to get a resolution by starting a new post with a description of the situation.  i.e. which Orbi models, with which firmware version.  A device connects to the Orbi "guest" network and receives an error message instead of a connection?
      The more specifics, the more likely it is that someone will have a useful comment.
      hphan1229
      Not yet.  I have tried other suggestions that I found online but didn't seem to help.
  • Retired_Member's avatar
    Retired_Member
    Why??
    Lots of problems with 2.5.1.8.   Many have reverted back.
