Bing-Stroller
Oct 24, 2017Luminary
Help with Asus Compatibility and Orbi
Hi,
I am seriously considering adding an Asus router to my setup for various reasons and after reading countless reviews I have narrowed it down to the following 3:
ASUS RT-AC68U AC1900 Dual Band
ASUS RT-AC87U AC2400 Dual Band
ASUS RT-AC3200 Tri-Band
So my question is:
Is anyone running any of these with an Orbi or have any experience of them that would help with the decision of choice.
TIA
Billy
what is the reason for the asus router ?
yes you can run the orbi in ap mode as wifi only and run a router in front of it with its wifi disabled
but if you want a better router get a specific router something like a ubiquiti edge router
the asus wifi wont play nice with the orbi
- Bing-StrollerLuminary
To clarify,
The Asus would be in router mode with WiFi turned off and the Orbi in AP mode with WiFi on.
sure that works fine , its actually how i run my orbi as i depend on the aiprotect etc of the asus
as far as which asus , avoid the 87u as its problematic , and you dont reallyneed a tri band router in the rt3200ac , the rt-ac68u is ok but router wise i would be aiming at the fastest cpu and most ram you can afford , perhaps look at the rt-ac3100 or rt-ac86u if you can afford them
or as i said look at a dedicated none wireless router like a ubiquiti edge or micrtik router
- j1nApprenticeAfter using the Orbi system for six months and talking with others in the Netgear Community, I’ve decided to try out using the Asus RT-AC86U Router in front of the Orbi System (I have the Orbi RBK50 + 2 sattelites and also the Outdoor Orbi satellite (RBS50Y). It sounds like you just put the Orbi system in AP mode and run the Asus router with the Wi-Fi disabled. Did you try this setup? If so, how is it working and also do you have any tips that you learned while using this setup? Thanks! Jason
