Markinportland
Sep 19, 2016Aspirant
How far away can you place the Orbi Satellite?
I have a detached garage with a guest apartment above. It sits about 80 feet from my existing Comcast modem and Apple router in my 3500 SF house. I have tried two Netgear extenders with poor results. I want to be able to use a laptop, mobile devices, and Amazon Firestick in detached apartment.
Will Orbi work for this application?
If so, how far away can I place the satellite from the base?
Will I need a second satellite for the house?
Hello Markinportland
Each unit can cover up to 2000 sq feet this will vary based on your environment. Also later on when we are selling individual satellites you can have up to 3 satellites with the one base.
DarrenM
- DarrenMSr. NETGEAR Moderator
DarrenM
- MarkinportlandAspirant
Hi Darren,
Thanks for the info. I still really need to know if there is a max distance that you can place the satellite? Has NetGear tested this?
That really depends on the environment of your area I can not give you a exact number but our satellites do have a LED indicator that lets you know if you are to far away from the base for a good connection to help find how far away you can put the satellite.
DarrenM
- itGeeksApprentice
Your sitiation is one exsample y I keep pounding Netgear as to the need of Eithernet backhaul, I have the same situation here and I don't think the 5HGz WiFi link is going to be strong enough to be any use. Come on Netgear give us Eithernet backhaul support on the sattlelights. The need for this support is only going to get wors before it gets better.
