ChihSiang's avatar
ChihSiang
How To Disable 5g Permanently On Orbi Router
Hi all, I have a need to disable the 5hz band permanently on my Orbi system but I can't seem to find any way to do it via the app or via Oribilogin.com. Can anyone help to advise if there's a way to do it?
  • you could just set up the guest 2.4 and use that, unless somehow the 5 ghz is affecting something else.  I think you can turn the power down though?
  • I use a Netgear X4S to stream Blu-Ray over the air. Unfortunately, I could only use the lower channels in the 5 GHz band on the network bridge (WD My Net). This coincides with the 5 GHz channels used for the Orbi, which reduces the bandwidth dramatically. This makes streaming impossible. I'm not afraid of the command line so if Netgear could point me to where I could disable the /etc/config/wireless file from being overwritten, that would be great. Changing ath1, ath2, and ath11 to disabled '1' gets overwritten when running "wifi reload."
  • FURRYe38's avatar
    Tring to disable 5Ghz would be counter productive and would not help since this is a MESH system which depends on both radios running. Kind of defeats the design and purpose of a wireless MESH system.
    • avtella's avatar
      avtella
      Prodigy
      Orbi isn't exactly a "Mesh" product because it uses a dedicated backhaul (5ghz in this case via a 2nd 5Ghz radio). This makes it better performing than its Mesh counter parts like the Google Wifi etc as you dont lose bandwidth from the first to last satellite as its in a star topology. They did add the chain feature now though. Anyhow due to the way Orbi works, you can't disable the 5Ghz radio via GUI. Probably can via telnet though, but you would lose connectivity with the satellite unit. For your purpose you were probably better off with an extender instead of the Orbi.
  • Retired_Member's avatar
    Retired_Member
    ChihSiang wrote:
    Hi all, I have a need to disable the 5hz band permanently on my Orbi system ...
    why?
