dunkens's avatar
dunkens
Apprentice
Jan 16, 2019
How to get an RBS40 working with nighthawk rax120 ?
Hi
Is it possible to add and rbs40 to an rax120 router ?
Want to use the rbs40 as an extender
How should it be setup in that case ?
rbs40 is wired
the rbr40 is broken ,
  • dunkens wrote:
    Hi
    rbs40 is wired
    The RBS40 is a satellite. You need an Orbi hub to make it work.
  • michaelkenward's avatar
    michaelkenward
    dunkens wrote:
    Hi
    rbs40 is wired
    • dunkens's avatar
      dunkens
      Apprentice
      As the sat has been in the network eariler , cfg with the same wifi settings as the rax router it seems to work .......
      the orbi sat is connected via wire to a diffrent part of the house , and there is full wifi coverage  , if the sat is turned off it became a deadspot
      and if i login to the sat i can see devices connected to it
      Connected Devices
      Attached Devices
      Refresh
      IP Address Device Name MAC Address Connection Type
      192.168.0.3 Sony Xz2 38:78:62:01:C3:56 5G
      192.168.0.13 Unknown 00:0E:58:5D:F6:3C 2.4G
      192.168.0.22 LAPTOP-ZENBOOKU 10:02:B5:2B:38:92 2.4G
      • FURRYe38's avatar
        I have noticed that if the RBS is initially setup with a Orbi router, and you remove the Orbi router and replace it with a non Orbi router, leaving the RBS connected via LAN cable, the RBS seems to work well as a wired AP. I would presume that if the RBS was factory reset that it would need to be setup with the Orbi router again to make it work as the RBS doesn't have any settings in it's UI for configuration. It's configuration is automatic from the Orbi router.
        Connected Devices
        Attached Devices
        Refresh
