chrza
Feb 22, 2017Guide
How to see exact Wifi quality between RBK50 and RBS50 after installation?
Hi!
I would like to see a feature where I can see the excact Wifi speed between the Orbi Router and satellite. While first installation the light was blue but I found that the speed isnt very good. So I copied a large file and experimented with the position of the satellite. The performance gain was from 55 Mbit/s to 420 Mbit/s! It would be nice if there were an expert feature for optimising the position of the satellite! Its insufficient to only rely on the colors!
- DarrenMSr. NETGEAR Moderator
Hello Chrza
That is a great suggestion I would suggest posting it in our Idea exchange board.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
DarrenM
- JMU1998Luminary
Excellent suggestion very useful feature indeed thanks for bringing it up.
- nsfwAspirant
Not 100% sure this is helpful, but under Advanced-> Click the "Show Statistics" blue button
Look at the last line:
WLAN Backhaul
My status is:
1733M
Wonder if you move it closer or further if you see this number change. Could be an indication of how well you've placed your satelite.
- loomis1975Luminary
I'm pretty sure we had the discussion about that number back in September. Pretty sure its just a label....Static.
- JMU1998Luminary
Looks static mine says same. I truly wish someone at Netgear will wake up and unlock this machine's potential. ORBI is using a Qualcomm IPQ4019 which is a 720Mhz Quad core Processor!! Paired with 512Mb of RAM and 4Gb of flash and a wired backhaul can't be added via Firmware??? Seriously?? not even offer wired backhaul in AP mode?? Seems a massive waste of a powerful machine limiting it's potential because of poor Firmware features.
I have made the same statement on the currently ongoing Netgear idea exchange as well hopefully it gains traction.
https://community.netgear.com/t5/Idea-Exchange-For-Home/Netgear-Orbi-Wired-Sattelite/idi-p/1145210
