gvarsity's avatar
gvarsity
I have 1 RBR50 router and 1 RBS50 satellite losing connection to router
Since this morning I have been having to power cycle the orbi every hour or two because it loses connection to the router.  Ran firmware updates and the router has been consistently solid.  I have rebooted the router.  The problem started before the firmware update and is persistent after the update. Turned off access control per some other google results to no effect.  Is a reset to factory settings the next step?  It is really irritating and I would prefer to use the Orbi than the router built in wi-fi.
Thanks
