vegascaptain
May 29, 2017Tutor
IOS connection problem
I've had my Orbi RBK50 since January. I have had connectivity problems like the rest of you with my IOS iPad and iPhone devices. I have the latest firmware (V1.10.1.2), but the problem keeps getting...
gmjones38
May 31, 2017Aspirant
I got my Orbo a week ago to replace a set of Apple Express routers. I am experiencing the same issues with dropping connections. It got so bad, I had to reconnect one of my airport express units in order to stream from my ipad. Whenever, I would stream something it would work for a while, then the connection would drop.
I would be interested in testing the beta software if that helps solve this problem. I have a very large house 6000+ with the base and 2 satellites which all seem to have good connections with each other.
Greg
