Kajmon
Apr 15, 2020Aspirant
iphone and all ios devices are not backup since I got Orbi Router
Hi,
I got new Orbi RBR50 router & one speaker satellite 3/26. Since then, all my iphone & ipads are not backing up.
They all automatically backup to icloud before. I tried 'Maunal back up', Turn on & off. Reset ios devices. reset network setting. Reset router setting... But nothing work.
I really like this router, but all 6 ios devices at home are fail to back up. What should I do?
Thank you.
Are you using the same SSID name and PW on the Orbi system from the prior wifi router?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- KajmonAspirant
-> No, I changed. I took default name - ORBI39 & make new passowrd.
-> Router Firmware Version V2.5.1.8
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?->Optimum is my internet provider. Modem is Arris TM1602A .
Thank you very much for help!!!!!
Try the prior SSID Name and PW? I would recommend not using the default SSID name. Thats mostly to get the system setup initially and users are encouraged to set a different SSID name.
