tlf_mb
Apr 12, 2024Aspirant
Is the Orbi Satellites compatible with Nighthawk RAX52.v2?
We have a 2100 sqft home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID . Can I hook up the Orbi Satellites to my Nighthawk router via ethernet port, without hooking up Orbi router?
Well as long as your not using same channels betrween the RAX and your perspective AP, then should work ok.
No. Orbi satellites only connect to there perspective model Orbi router. Don't connect to non Orbi systems.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
tlf_mb wrote:
We have a 2100 sq.ft. home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID .
AX6 is a marketing term describing more than one Nighthawk router. It would be helpful to know the actual model number of this router. When replacing one WiFi router with another, the common practice is to configure the new router with exactly the same WiFi credentials (SSID/password) as the one being replaced. This allows every device in the house to connect automatically to the new router and also allows the user to "go back" to the old router by simply exchanging the hardware.
It also would be useful to understand the reasoning behind the purchase. i.e. what prompted purchasing a stand-alone WiFi router to replace a mesh system of three access points.
With that Orbi Pro system now officially "End of Life", there may be more Netgear customers considering "what to do?"
The subject line has the model # of the router there asking if the Orbi satellites will not connect too.
Great start for my morning! Thanks.
- tlf_mbAspirant
Model: RAX54v2
AX5400 Wifi6 Router.
It's a Nighthawk AX6 wifi router and I like want to add an Orbi satellite without a mesh router. Will it work? Thank you for your help!
