cool2562's avatar
Oct 04, 2018
Issues after upgrading firmware
All my WIFI devices are connecting to the router instead of the closer sattelites after new firmware update.
  • Sorry forgot to mention I am on 2.2.1.210 now. Also realized my SkyBell HD stopped working after update as well.
    • Bullyterrier's avatar
      Bullyterrier
      Star
      For what it’s worth I had multiple problems after using the gui to update and currently have no problems after manually downloading the img file and using the gui to manually apply it (using the prompt to overwrite the same level). I followed the manual update with a factory reset too having tried just a factory reset on the gui update and found it didn’t fix anything.
      Only thing I can see different is my WAN ping has increased from 12 to 15msec (consistent and to the same test server) from the point of upgrade. Speeds are similar but slightly lower than before - within the scope of variability of a new VDSL sync.
      I have wired devices on the router but none on the satellite and use wireless backhaul with daisychain off.
      It certainly looks as if my device(s) were left in a bad way by the gui autoupdate.
  • Retired_Member's avatar
    Retired_Member
    Are the Sats even functioning?  Blue light, magenta light, no light..??
    • cool2562's avatar
      cool2562
      Star
      No light but all are accessible via network map and logging into the main router.
      • FURRYe38's avatar
        Let us know if changing the power output does anything.
        Also try the manual FW update process...
  • i have the same problems, and i found that although it show to connect the RBR20 , but actually is connect to the closer sattelites(becoz i just shut down the sattelites and find that the my phone wifi signal disappear.) i guess is the bug of showing the wrong sattelites.
    *i try factory reset few times
    • FURRYe38's avatar
      If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
      Disable MIMO, Fast Roaming, IPv6 as well.
