ronfriedman's avatar
ronfriedman
MacBook Air gets dropped from internet by OrbiRouter RBR50
Hi:  My wife has a 2 year old Macbook Air which suddenly started losing its internet connection intermittently but it happens several times a day.  I use a hardwired connection and have had no similar issues.  That leaves the Macbook Air and the Router as possible culprits.   I first investigated the Macbook Air  (with no success yet) but now wonder if there are some router settings on the Orbi RBR50 which might be causing this.   Would appreciate any advice regarding possible router settings changes which might solve this issue.  Thanks
  • FURRYe38's avatar
    hat Firmware version is currently loaded?
    • velaramon's avatar
      velaramon
      Guide
      If you find a solution, please post it. You're not the only one having this problem.
  • FURRYe38's avatar
    Any progress on this?
    • ronfriedman's avatar
      ronfriedman
      No progress on this.  My wife still gets dropped from the internet.  She usually is dropped from the internet when playing interactive bridge on BBO.com.  I still suspect the Orbi Router.   FURRYe38 asked me a bunch of questions--see below with my response in [brackets]:
      What Firmware version is currently loaded? [v2.5.1.16]
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?  [It's an Xfinity wifi capable dual banc 802.11ac]
      What is the size of your home? Sq Ft? [3000 sq ft]
      [~40 ft]
      What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. [11 on 2.4Ghz and 40 on 5Ghz]
      Any Wifi Neighbors near by? If so, how many? [lots of WiFi neighbors--I would say 10 show up on my network list]
      [done]
      Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).  [done]
      I am wondering if adding another satellite would likely help or even upgrading to the new ORBI product in WiFi6?  Thoughts and suggestions welcome.  Many thanks
      • FURRYe38's avatar
        What mode is this modem working in? Router or Bridged?
        IF this modem/ONT has built in wifi and a router, this maybe a one cause of problems with Orbi if it's not fully bridged. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
