sojourn_out's avatar
sojourn_out
Multiple Network names/passwords
Hello!
I own a 6,800 sq. ft, 8 unit. Airbnb property. I have an Orbi router (RBR20) with 2 satellites (both RBS20), because the website showed me that this mesh system could cover 6,000 sq. ft.
However, all 8 units do not receive the same coverage. I need to get some extra satellites or Orbi Voice devices, but I am in need of help with this.
Our main goal is to have a different wifi name and password for each Unit.
Ex. Unit 1s wifi name would be Sojourn1, PW: SojournUnit1
Unit 2; Sojourn2; SojournUnit2
and so on.
Is there a way I can do this with multiple routers or satellites?
What would be the best recommendation?
Thanks for taking time to help!
  • FURRYe38's avatar
    You may need to look into a business class system for your needs. Orbi home products is based on a signal wifi SSID and single PW. Something that you won't be able to use for your needs. Orii 20 series only supports up to 6000sq ft and not beyond. Somnething a 50 series would do better however again, would not work for you wifi configuration needs.
    You might try Orbi pro however not sure if that will support your needs either. I recommend looking into business class wifi systems for your needs.
  • sojourn_out wrote:
    Hello!
    and so on.
    To do this correctly you would need Enterprise APs controlled through a central management system, which could get quite expensive. Wiring the building and adding multiple routers may have interference issues, because of 8 routers in a small area.
    Since the RBR20 is a less powerful Orbi system with less coverage, it would be cheaper to get a more powerful Orbi system like the RBK53 and add more satellites to it. Depending on the layout of the building, 1 router and 4 satellites may cover it. However you will have 1 WIFI SSID for main and 1 WIFI SSID for guest.
      • Mstrbig's avatar
        Mstrbig
        Master
        sojourn_out wrote:
        Mstrbig Is this what you would recommend then?
        Correct. The best solution is to stay with a more powerful Orbi system, forget the multiple SSIDs, as the expense can get costly, and add satellites as needed.
