huntewe's avatar
huntewe
Multiple problems- RBR-50
I JUST SET UP THE ORBI RBR50 DEVICE AND I CANNOT GET MY PELOTON APP OR PANDORA TO RUN ON MY IPHONE WHEN I CONNECT TO THE ORBI NETWORK.  ANY SUGGESTIONS?
  • SW_'s avatar
    SW_
    May 09, 2019
    huntewe wrote:
    The Orbi system was in router mode, I changed it to AP Mode.  No difference.  I turned off the wifi on Uverse router and it is now working.
    Just curious, did you happen to use the _same_ SSID for both Uverse router and Orbi?
    Is DNS working?  For example, does YouTube app work?
    • Chuck_M's avatar
      Chuck_M
      Mentor
      You may want to start at the beginning so people can help you.  Technical experts need more information such as:
      What type cable modem are you connected to?
      What firmware does your RBR50 have?
      How many satellites do you have?
      Does your phone really connect to Orbi or do you just think it is?
    • huntewe's avatar
      huntewe
      Yes, Youtube app runs fine.  Peloton will start but the on demand videos will not play.  Pandora also starts but music doesnt play.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    • huntewe's avatar
      huntewe
      I verified the firmware is at the most recent version (2.3.1.60)  I have a UVerse router, model 5268acfxn.
      thanks for your help
      • SW_'s avatar
        SW_
        Prodigy
