bfrank
Aug 22, 2017Aspirant
Multiple Satellite Placement
I'm curious about placement of multiple satellites with the Orbi system. I understand it is best to have the router in the center. Is there any drawback (or benefit) to putting two satellites relat...
- Retired_MemberAug 22, 2017
If the satellites are too close to each other or the router, the WiFI signals will bounce back and you may experience intermittent connectivity or slow speed. A distance of atleast 20-25 feet should be there between the satellites.
Retired_Member
Aug 22, 2017If the satellites are too close to each other or the router, the WiFI signals will bounce back and you may experience intermittent connectivity or slow speed. A distance of atleast 20-25 feet should be there between the satellites.
- LijoAug 28, 2017Aspirant
I would like to use the Netgear Orbi RBK50 Set in my house with 3 levels. The main router is on the top floor. Now I'mplanning to put the base on the top, one satellite on the middle floor and maybe another on the bottom. Make this sense, or should be the base in the center?
- DarrenMAug 30, 2017Sr. NETGEAR Moderator
The base should be in the center for the best configuration.
DarrenM
