WARNERP42
Jan 07, 2022Tutor
N300 WNR2000v3 Router Connecting to Roomba i3
I recently purchased an iRobot Roomba i3 but have been unable to set it up due to Wi-Fi connection issues. I run through the Roomba set up, but when it gets to the point of connecting to Wi-Fi I get a popup saying the router disconnected. The router has Firmware v1.1.2.18. I can see nothing in the administrative screen that would be causing an issue and cannot find anything regarding 2.4 vs. 5 GHz in the settings. I do not know enough about Wi-Fi to go changing things in the settings.
Arris SBB200? Do you mean SB8200? There isn't an SBB
If so, you're bottleneck is big time on that router. Its a old base model N300 devices with only 10/100mbps connections. Its not gigabit either. An upgrade in the future might be a good plan.
What security are you using on the router?
You posted in the wrong product group. I believe you are looking for: https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thanks! I just posted this in that product group as well.
The WNR2000 doesn't have 5ghz.
What firmware is on it?
What modem/gateway is it connected to?
Thank you! Here are the answers to your questions:
That is interesting to learn.
It is on Firmware v1.1.2.18.
It is connected to an Arris SURFboard SBB200 cable modem.
