jdanham
Jun 15, 2017Guide
Need to EXTEND Orbi outdoors
I purchased this system 2 months ago and in our 2500 sq ft, 3 level home, coverage and performance have been exceptional, however once you go outside to our patio - which is less than 25' away from t...
DarrenM
Jun 16, 2017Sr. NETGEAR Moderator
Hello jdanham
I do not think a extender will help its hard to get strong wifi signal outside you may just try and re position your satellite and find if there is a better spot that will get signal to your patio.
DarrenM
peteytesting
Jun 16, 2017Hero
or jus go buy a external wireless access point and run it back to your router via ethernet , connect it to your frre to air antenna point and you have outdoor wifi all over the place , nothing to do with orbi btw as they dont have an external weather proof WAP
