jdanham
Jun 15, 2017Guide
Need to EXTEND Orbi outdoors
I purchased this system 2 months ago and in our 2500 sq ft, 3 level home, coverage and performance have been exceptional, however once you go outside to our patio - which is less than 25' away from t...
jdanham
Jun 25, 2017Guide
OK I went ahead with purchasing the RBW30 Satellite, have placed it on our patio (protected from the elements) and successfully added it as my 2nd Orbi satellite.
Now I may have a misunderstanding about the underlying architecture here, but I tested 4 different locations in my front yard including the patio and my internet speed tests came back exactly the same. The outdoor unit is further away from the router unit, but it is maybe 25 feet from the other satellite unit that came with the kit. Since I had like almost 50% improvement in my wireless when I installed Orbi, I guess I was expecting the addition of this one to improve on the down/up speeds outside. Or is it more a case of the throughput will remain the same but the coverage in those areas will be better? I will run additional wireless signal tests, but now I am wondering where I am going to see the value of it. Maybe better to place in the basement?
peteytesting
Jun 25, 2017Hero
when you say internet speed , what do you mean , eg using speed test ? and what is the max speed of your internet connection as this wont change
- jdanhamJun 25, 2017Guide
Yes speed being the Ookla Internet speed test. My ISP service is for 50mbps, and what impressed me the most about Orbi was I went from about 30 down and 5 up to over 50mbps and 12mbps respectively. In comparison, plugging directly into the ISP router my speeds were only a little better. I think my assumption that my new satellite was going to provide faster speed than 30mpbs was incorrect. But in case I'm wrong about that I was hoping someone might confirm otherwise. If everything hinges on proximity from the satellite and the main Orbi router, then I can see the mesh acting more as a coverage extension rather than a performance enhancement - again I am open to be corrected at any time :)
- peteytestingJun 25, 2017Hero
hi
yes its sat to router and in my testing its about 15 meters or less from router to the sat is about the right distance , the orbi isnt actually mesh in desigh and is more star based so each sat connects back to the router ( note : this may change in the furure depending on what the dev team do )
any greater distance from router to sat and the backhaul connection will be effected and thus slower speeds from the sat's
the idea of the orbi is to provide whole home wifi coverage , here i have 100/40M fiber and prior to getting orbi and with my big honking router in the center of my house the outer room suffered from low wifi coverage and thus slower speeds as a result , now with the orbi installed i get 100/40M anywhere in the house on 5 gig wifi with ease
i have mine setup
sat ---- router ---- sat
OK good information thank you. I'm overall happy with the product so far and now I have a clearer understanding of limitations. I hope that I don't end up with the reported problems with dropping connections!
