Alankirsh's avatar
Alankirsh
NEO Ankuoo
Is there a way to get the Ankuoo NEO switch hooked up to the Orbi WiFi system?
  • FURRYe38's avatar
    You might contact the Mfr of that device and ask for help and information regarding set up for it.
    • Alankirsh's avatar
      Alankirsh
      Is it possible to just get the 2.4g so that I can sink with my NEO Ankuoo light switches. With the dual signals I’m putting out from the Orbi, the switches are not compatible.
  • FURRYe38's avatar
    There is a thread on here that others have posted about splitting the one SSID name between 2.4Ghz and 5Ghz. Something you can try, however is not supported by NG. Orbi system are designed to run with smart connect using a on SSID name and pw for both radios.
