orbira's avatar
orbira
Apprentice
Jan 12, 2019
NETGEAR Orbi AC3000 satellite LAN ports stopped working
Hi
I am using Orbi router for last 2 months just fine. Today morning the LAN port son router suddenly stopped working. One of the satellite was connected over wired backhaul, that also switched to wireless. Rebooting the router does not help. Resetting the router, occasionally starts working but goes bad again if you try renewing lease on the machine connected over wire. There is a 8 port switch connected to the router and assuming that could be the issue I bought a new switch but no luck. Called Netgear support and after very priliminary reboot/reset exercise, they concluded bad hardware and I don’t really want to get a refurbished hardware just after 2 months of use. Is there anything I can try/test to see if it will work?
Thanks
  • What wired devices are connected to the LAN ports?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    Had the Orbi been powered OFF (pull power adapter from wall outlet) for 1 minute with out anything connected to the LAN ports, then powered ON with maybe just one wired PC connected to the same LAN port and test the others to see if the port is working or failing?
    Swap LAN cables as well.
  • The issue may not be device hardware related.  My RBS50 Satellite went out last night also.  None of my lan ports are working and if a device is conected wirelessly, I can't get safari to open pages and receive a SSL certificate error
    • orbira's avatar
      orbira
      Apprentice
      I think so too. How did you fix your issue? In my case, I have tried everything...
      • rwright727's avatar
        rwright727
        Tutor
        I don't have it working yet.  I manually applied the latest firmware (V2.2.1.210) and orbilogin.com reports "Update failed."
  • FURRYe38's avatar
  • > What wired devices are connected to the LAN ports?
    Directly to the router I have
    1. Switch
    2. Lutron hub
    3. Backhaul to one of the satellite
    I had TRENDnet TEG-S81g 8-Port Gigabit GREENnet Switch connected initially but when I suspected a bad switch first, I bought a NETGEAR - 8-Port 10/100/1000 Mbps Gigabit Unmanaged Switch - GS608NA. But that did not make any difference.
    Yes I did that. just powering off and on does not help, but isolating cables helped. It seems the backhaul cable to the satellite is the issue. Disconnecting that, lan ports start to work.
    To troubleshoot further, I connected that cable to the switch, instead of routers lan port directly, but that still causes lan ports on the orbi router to go down. I would assume, that switch would isolate the cable fault from the router, but doesn't look like it. Is there any debugging/logging that could help me why Orbi is bringing down the ports?
    That said, it is a cat 5e cable which is already laid out and hard to replace. I am buying a cable tester to see if the cable is bad or can I crimp the ends again.
    Thanks for your help.
    • FURRYe38's avatar
      Sounds like you found the culprit. Sometimes cable or the cable plug ends can be a cause of a problem. This would probably cause any routers LAN ports to fail possibly. The troubleshooting you did would be the best way to isolate this. You did that.
      I don't think logging would mentioned this, however you might look at the logs after testing the cable in the LAN Port, then look at the logs to see if it noted anything.
      Glad you found the main problem. Be careful with the Green Ethernet switch, seen others with problems with those kinds of switches. The 608 should well best.
      • orbira's avatar
        orbira
        Apprentice
        Just to complete the loop (pun intended :smileyhappy:), as I said, I ordered a cable tester. Upon testing I did not find anything wrong with the cable. So to rule cable out completely, I connected the cable directly to my PC in basement and that did not create any issue. I was suspicious that the issue has to do something with spanning tree protocol because instead of disabling wireless backhaul, the router is choosing to disable lan ports to break the routing loop. Doing some googling on Orbi and spanning tree, seems like this was an issue with older firmware which should have been resolved in current firmware. Debugging further I noticed this innocent setting "Daisy chaining satellites" and turning that off fixed the issue altogether. Now with same cable I am wired backhaul for one of my satellites. Now my theroy is that there is still some bug/issue with spanning tree algorithm and can be explained as below (will only manifest if one satellite is connected over wired and other is over wifi)
        • Sattelite connects over wifi
        • Switches to wired for backhaul
        • So now there is one satellite is over wired and other satellite is over wifi
        • The wired satellite's wifi backhaul goes through other wifi satellite (assuming bug in code, the wifi backhaul should be turned off on both satellite and router, but it seems only gets turned off from router side)
        • This causes loop again, and this time instead of turning off both satellites, router chooses to turn off lan ports
        • Turning off daisy chaining resolves this issue as the wifi backhaul for wired router has no path to reach the router.
        Just a hunch, but hopefully some capable engineer from Netgear is reading this and can dig down further in code logic. Happy to repro the problem if someone from Netgear is willing to work together. Alternately, it might be a good idea to add, user selectable backhaul in the UI, so that for whatever reasons, STP/code doesn't do the right thing, users can choose to fix it manually.
  • I'm glad you found a solution.  Unfortunately, I did not.  My ports are still not working and if a device is connected to the satellite (iPhone) I am not connected to the internet.  I receive a SSL certificate error whenever I try to go anywhere (google.com).
    I looked at the logs and found that an automatic firmware update occured right before I had this problem.
    Initialized, firmware version: V2.2.1.210] Saturday, January 12, 2019 17:30:53
    Do you think I could try to revert to a previous firmware?  Would that be safe?
    Thanks
      rwright727
      Tutor
      Here are the steps I took to try and resolve this issue.
      1. Left the satellite off for 24 hours
      2. unplugged all ethernet devices from satellite
      3. turned on satellite and waited for it to connect to router
      4. manually updated (again) satellite to the latest firmware and got a sucess result
      5. plugged in one ethernet device (Arlo - NETGEAR).  This device is working if plugged into the router.
      At this time, my iPhone XR connected to the satellite and was unable to connect to the internet.  I get SSL certificate error.
      • orbira's avatar
        orbira
        Apprentice
        What does orbi report about internet connectivity. You can try to login to your orbi router using telnet. First enable telnet by going to orbilogin.net/debug.htm. From there you can see if you can resolve and ping external site e.g. google.com.
        Also so when you get ssl error, can you look at the certificate and see who is the provider of the certificate and what is the error.
