Alisdair73's avatar
Alisdair73
Netgear orbi RBR50 disconnection
I have the RBR50 with 3 RBK50 satellites. Recently the RBR50 (router) disconnects from the satellites and I have a flashing white ring on the RBR50. It is now doing this regularly and it causes my wi-fi to drop. I updated after this started happening to the latest firmware hoping that would help - it hasn’t. I can’t believe for an item the price this is that you only get 90 days support and that the stability is so naff! Any ideas? Other than it becoming a paperweight?
  • CrimpOn's avatar
    CrimpOn
    The Orbi router LED ring pulsing white indicates that the router is in factory default mode. This page lists the meaning of the power and ring LED's for Orbi router and satellite: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Once an Orbi has been configured and synced to three satellites, it is only supposed to return to factory mode if it has been "reset to factory" by holding a paperclip in the tiny reset hole until the power LED turns solid orange and then begins flashing orange.  If you have not caused this, then something is seriously wrong.  There is one other condition that causes a pulsing white ring: applying a configuration or updating firmware.  For this to happen over and over also indicates "something wrong."
    When reset to factory, the SSID returns to the one printed on the label and it no longer connected to the satellites, so your Wi-Fi network will be "gone"   until it is reconfigured and resynced.
    How long have you had the Orbi and where was it purchased from?
    • Alisdair73's avatar
      Alisdair73
      It was purchased from amazon in sept 2017. It was ok until recently
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enableding Beamforming and MIMO.
      Alisdair73
      Firmware 2.3.0.32 on router and the 3 satellites
      Orbi in ap mode
      Router is draytek 2650
      Home is 3000sq ft on one level with fairly thick walls in places hence 3 satellites
      1st satellite is now only 2m from router! As it sometimes dropped at 8m
      Mimo and beamforming enabled
      Channels auto will change
      1 Wifi neighbour for security purposes runs our security
      • CrimpOn's avatar
        CrimpOn
        You did not mention doing a "factory reset" after updating to the latest firmware?
  • I was out on a business meeting overnight and i get a message form my wife no internet and the orbi rbr50 had a white flashing light on top.  I had her plug directily into my cable modem and internet was on.  Came home this morn and reboteed everythinginsequence and could not get it to hook up to the internet.  finally i did a factory reset and and goit to come back online and recognized the satellites.  I agree thisis a very fast router. but i am quickly losing confidence in reliability.  I am current on firmware, but still having lapse in internet.  My wife cannot use zoom wireless as it freezes when it drops internet. Hence i was going to set up backhaul this weekend, but now i am considering scrapping the whole system.  less than 6 months old and a helluva investment with the orbivoice.  I have google wifi on the shelf never had a problem with it when in use.  My down load speeds on spectrum hardwired 4-500 mbs, wireless when the orbi is connected 125-135 mbs.  any suggestions appreciated beore i throw in the towel gegger
    • FURRYe38's avatar
      https://community.netgear.com/t5/Orbi/Orbi-setting-up-backhaul-with-spectrum/m-p/1723585#M56091
