Stuart07715
Apr 16, 2018Aspirant
Netgear orbi RBR50
Please help I have brought an orbi system with 1 satellite and wish to extend the coverage to another part of the house which has very poor coverage, do I have to use another orbi product ie satellite or plug in, or is it possible to do this with a cheaper option?
As I don’t really want to send another 130 pounds if I can do this cheaper as this area will most probably be used for just visiting web pages.
thanks for any help received up front.
- Streak2MasterI would first experiment with changing the location, if possible of the current setup to give you the coverage you need.
- Stuart07715AspirantThanks for your reply I have already tried this in a number of places, I need to get coverage to an anexxe which is built onto side of the house.
Any suggestions?
Thanks
