Chuck1806
Jul 27, 2026Aspirant
Network map
How do you remove an old satellite RBS50 that was damaged from the network map?
I open the satellite profile and can see the Details.
It indicates the Connection Type as "Offline" but no option to delete it.
Log into the RBRs web page using it's IP address using a web browser. On the Connected devices page there, if the RBS is OFF or not connected and had been there should be a Disconnect button for the RBS entry here that you can select to remove it from the system.
- Chuck1806Aspirant
I really appreciated you help
Thank you😎
Enjoy. 📡
