ConnectedNL's avatar
ConnectedNL
No connection with my router
Just purchased this set and downloaded the app. Went through the set up on the app but when it wanted to connect to my router, it says its ROUTER NOT FOUND.
But going to my Wifi on my phone, the ORBI WiFi is connected. Now I can't seem to finish the set up, although it seems to work.
Can this be because I have a 5 G T-Mobile device for my internet and not a 'normal' router?
  • FURRYe38's avatar
    Yes, the Orbi system needs a cable or DSL or ONT type of modem device that connects with an ISP service. Then the Orbi Router base connects with a LAN cable RJ45 to the modem device and then gets it's connection there.
    • ConnectedNL's avatar
      ConnectedNL
      So it's not possible to use the Orbit with a 5G wireless device? Or is there a workaround?
      • FURRYe38's avatar
        No. The Orbi needs a Wired LAN cable connection with a ISP modem that has a RJ45 LAN port.
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem?
