omolko's avatar
omolko
one of my satellite RBK 50 has lost sync
Hello I don't find any issue to this trouble.
firmware V2.7.3.22
I have reset every thing, put the satellite near the router, link them with an ethernet cable...
when I try to sync, the satellite starts with white flashing and ends with pink.
Thanks for any help
  • FURRYe38's avatar
    Try syncing the RBS first suing wireless sync.
    Also if you can get the RBS to sync, you might update FW as well. v.24 is available.
    • omolko's avatar
      omolko
      thanks for your answer.
      My orbi app says that my firmware is up to date...
      Of course I try to link it again wireless without success. I have a second rbs satellite which is linking without trouble
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello omolko,
        Welcome to the NETGEAR Community!
        Thank you for your post!
        I understand that you are having difficulties syncing your RBS50 to your RBR50. Please factory reset your RBS50 then sync the satellite to your RBR50.
        Best,
        Kevin
        Community Team
