HolmDK
Jul 02, 2020Aspirant
Orbi AC2200 with 3 satellites
I have had the system for almost 2 years, with 3 satellites it covers the whole house, and until now it has worked perfectly.
About 3 munth ago it started to be really unstable, the internetconnection drop out.
Sometimes its about 20 sec with no connection and other times its minutes.
I have tried to reset and start all over - no changes.
Its updated with the latest firmware, 2.5.1.16 - no changes.
My wired connection works perfect.
I hope there is someone who can help on this.
Thanks.
BR Jan Holm
What modem are you using?
Have you checked your modem signal strengths?
Do all devices have issues, just wireless devices, just wired devices?
Or is it just devices connected to the satellites?
Does it stay stable if you just try running the router (without satellites)?
- HolmDKAspirant
I have checked the modem signal strength, and its perfect.
Its only the wireless devices which have issues, the wired are perfect.
I will try without satellites.
/Jan
You can also try enabling/disabling:
Fast roaming
Beamforming
daisy chain (unless you're using daisy chain and need it)
