Dtomaso1's avatar
Dtomaso1
Follower
Jan 12, 2019
Orbi ac3000 rbk50 won’t connect to internet. Brand new. First setup.
Hello, wifi working. Connected Devices listed on orbi app. Can check internet speed on orbi app. But no internet connection. Have rebooted, tried new cables. Tried old router. Works fine. Frustrated. Please assist. Thx
  • I kept getting the message saying not connected to Internet while setting up the Orbi RBK50 on my phone. The problem was that I had private DNS mode setup on my phone. Once I disabled this, everything worked fine.
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    Did you power OFF the modem and back ON before starting the Orbi router?
    For modems with built in routers:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • raven_au's avatar
      raven_au
      Virtuoso
      Clearly the new wireless will be different.
      But the AX chipset should be able to provide AC support as well.
      So the question becomes can AC based Oribi devices be used with the new AX based Orbi devices.
      For example, if one gets a Router plus Satelite AX based pack can AC based satelites that customers already have be used with the new AX based Orbi router?
      Oh wait, I seem to have posted in the wrong thread ... sorry.
  • All my devices connected fine to the router but my partners surface pro and google pixel could connect to Wi-Fi but would have not internet or drastically slow internet.
    After tons of research, figured out that setting up the DNS in the adapter settings fixed the issue.
    Step 2 in the following website:
    https://www.drivereasy.com/knowledge/fix-dns-probe-finished-bad-config-error/
    A question to support. Why do I have to do this for some devices? Surely this is a bug?
    • FURRYe38's avatar
      Could be a number of reasons. I would start with ISP services and device first. Modem router combos can cause problems.
      You can configure DNS on the Orbi router to use other DNS services besides ISP DNS. I use 1.1.1.1, 4.2.2.4 and Quad 9.
  • FURRYe38's avatar
    Any update on this?
    • Chuck_M's avatar
      Chuck_M
      Mentor
      He had conflicting or competing DNS entries in some network adapter properties:  Two threads above he said:
