Faxman's avatar
Faxman
Orbi AC3000 router solid Magenta
After a couple of year of problemless use  I have now ended up with a solid purple ring on my router and the satelites. I have one computer connect with a fixed cable to the Orbi router and this computer gets internet access. Over wifi I can barely connect to the system and I once I succeed in connecting to the wifi I can not access my network settings through the Orbi App, it can not detect the products. Wifi units have no internet access. I have rebooted the system a couple of times with the same result everytime - a solid magenta ring on the device and no internet access. Since my computer that is directly connected to the router has internet I know the problem is not with my ISP.
Any thoughts on how I can fix this?
  • Faxman's avatar
    Faxman
    Sep 16, 2021
    I had access to an extra router, did a factory reset on it and my old satelites, and then set everything up again using my old network details. Now my network works again. Not sure if I had a hardware fault, but that would be my guess.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    • Faxman's avatar
      Faxman
      Yes - I have done the 1 min shut off of both the fibermodem and the Orbi router as well as the satelites.
      When it comes to firmware I can not check which version I have since I can not connect to the Orbi units with the app. I have not preformed any update over the last 6 months, but I do not know if any automatic updates could have happened since.
      My modem that is connceted to the fibre is a Inteno Broadband Technoloy AB, model name XG6846
      My unit is a Orbi RBR50 router.
