WRPowers
Jan 07, 2019Tutor
Orbi and extender
I have recently installed an RBK50 Tri-band router and satellite - both on either end of the main level of my house. I have a basement location were there seems to be s signal "null" where a security camera can't connect. Is it possible to use an existing Netgear EX6100 as an extender to keep from haivng to purchase a second RBS50?
JoeCymru wrote:
Let me spend your money. Rather than trying to go really low cost (and I have one of those Netgear extenders if you really want to go cheap ... I put it away when I got Orbi because one of my main goals was to make that mickey mouse EX6100 go away and get rid of the multiple SSID's).
If it was me, for filling the hole, I would go with a cheaper, smaller Orbi. Say an RBS20 add on, or and RBW30 add on. Again, it is your money, but for all the hassle of using an extender with Orbi for what it is actually going to put out, I would throw some additional bucks at it (but not for another RBS50 for sure). Just my opinion, naturally.
For this application, to cover a security camera in a basement, where no roaming is needed, I really don’t see an advantage for using an Orbi satellite over an extender apart from central management.
An additional satellite will have the same or more level of noise on the existing Orbi wifi network.
- gamesapkAspirant
Orbi and extenders can work well together when you need stronger Wi-Fi coverage in areas where the main router signal is weak. A stable setup can make streaming browsing and gaming smoother. For casual gaming entertainment some users also explore options like Y999 Game as part of their online entertainment routine.
- y888gameAspirantundefined
- yasir9223Aspirant
- JoeCymruVirtuoso
- ekhalilMaster
- WRPowersTutor
Thanks for the feedback. I agree the best approach is to not be so cheap and simply add another satellite. Having the main level covered by the router and first satellite and adding a second satellite for the basement is certainly the better way to go. I think it'll also help to avoid any issues related to HVAC ducts interfering with transmission.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.You can give it a try and see if it will connect and help extend the signal some. Just be aware there maybe differences in connetion rates and speeds between the Orbi and EX6100. If it doesn't seem to work well, I would get you same RBS50 satellite to place down in the base ment.
- WRPowersTutor
Home is about 5000 sf. Straignt line distance between the router and satellite is appx 55 ft. - two walls in between. Camera one floor below about half way between the two. Could be the best solution is just another satellite. Just though I'd try repurposing the previous extender. Thanks for your response.
- ekhalilMaster
Yes, but please make sure the extender uses a different SSID than Orbi's, so that your devices will not start roaming to the extender.
Please note that the extender will use the same radio channel(s) as Orbi's and will have some noise on Orbi in the area that the extender has range overlap with Orbi. If the traffic in the extender is not high this noise will have minimal effect.
- WRPowersTutor
How do you set an SSID for the extender? I thought it just mirrored whatever the SSID was for the host router. Wouldn't mind having the security cameras on a different network. Just thought I'd try it before springing for another Orbi satellite. Thanks.
Let us know if you were able to get the extender working for your needs and if it worked or not for you.
