mfaust
Jul 05, 2020Aspirant
Orbi and Nest
Hi, thanks in advance for any help.
I have an RBR 40 router setup with 4 satelittes throughout our house. We have been having issues with our Nest cameras, which have been intermitently losing connectivity.
After multiple attempts to diagnose with our ISP and with Nest, the folks at Nest believe the issue is with the broadcast from the Orbi.
Specifically, when I reset a camera to factory settings and then go to add it to our network, there are somewhere between 7 and 9 listings for our network (all with the same name).
As I understand it, the Orbi should just be broadcasting one SSID, so they believe there is something in the broadcast that is causing confusion for the camera and that it keeps losing connections as it tries to change the connection.
Has anyone had any similar issues or any suggestions for what might be causing this?
Thanks!
Orbi does broadcast 1 SSID, it's your camera who is detecting each of the signals from the RBS and RBR and displaying them separately. Try turning OFF the RBS leaving the RBR online and then set up your camera.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router- mfaustAspirant
Thanks FURRYe38. Some answers below:
Firmware V2.5.1.16
The router is connected to an AliceOne box - Its made by Sagecom - model DGCI384. After a bunch of back and forth with the ISP, I was finally able to get them to just use the box as a modem and let me use the Orbi as the router.
The RBS that was the closest to the problematic cameras (Satellite-3) was less than 10 feet and it was daisy chained to another satelite with less than 30 feet distance between each.
I went ahead and just removed that satelite completely and a few interesting things happened:
For a few minutes in the network map, it showed multiple instances of another satellite (Satellite-4). Also, I started watching the cameras that are having issues in the list of attached devices. When they lose the connection, it says they are connected to "Orbi Satellite" with no number after it for a few seconds and then it reconnects to a numbered satelitte.
The RBS in the closet would not be recommended. 10 feet is too close if thats the distance between it and the RBR.
Did you reboot the RBR after turning OFF the RBS and then let the cameras connect to the RBR alone and see if the RBS status on the RBRs web page shows disconnected?
Has a factory reset and setup from scratch been performed since last update?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- sarwatkazmiAspirant
mfaust wrote:Hi, thanks in advance for any help.
Thanks!
same issue i am facing . please help me i shall be very thank full to you..- CrimpOnGuru - Experienced UserWhat is the model of Nest camera? Where do these multiple names appear? (Nest app?)
