Cajigasjd's avatar
Cajigasjd
Follower
Nov 19, 2018
Orbi and satilite go offline daily
Model RBR20 filmware 2.2.1.210
WiFi Connection goes off daily. I need to reboot it via app to get it back online. Please help!
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
  • I have had a similar problem. My orbi was great for about 95 days. now, i have to reboot it daily. My Asus would do this automatically. It is annoying and frustrating.
    • FURRYe38's avatar
      What model Orbi do you have?
      What FW is currently loaded?
      Is the Orbi system operating in Router or AP mode?
      What WPA security modes are you using?
      Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi duanemusser
      Do you have the latest firmware (v2.3.0.32) installed? If not, please update the firmware and let us know of the result.
      Blanca
      Community Team
      • duanemusser's avatar
        duanemusser
        Blanca,
        I do have the latest firmware.
        As far as the previous suggestions, my signal inside is fine. It keeps dropping connection to the internet. My fiber modem is working fine.
        Unless my ISP started enforcing DHCP expiration, I don't know what else would case it to stop connecting.
    • FURRYe38's avatar
