angularone
Jul 30, 2017Aspirant
orbi and U-verse how to keep firmware updated
ok guys I used RonV42 instructions to hook up orbi a guest SSID. all is working well. my question is on the lines of how do keep the firmware updated on the orbi?
> [...] how do keep the firmware updated on the orbi?
I know nothing, but there is a whole Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Also, an Orbi "support" page with a "Firmware and Software Downloads"
link (which is where I'd probably start):
https://www.netgear.com/support/product/orbi.aspx- DarrenMSr. NETGEAR Moderator
Hello angularone
The firmware is updated automatically.
DarrenM
- angularoneAspirantI understand that in orbi mode. But since I set it up under the att U-verse as an Ssdi guest it does not show under orbi app. So how does one keep firmware updated?
- st_shawMaster
As said already, the Orbi updates firmware automatically, with no user input required. This, of course, requires Orbi to be on a network with Internet access. I have no idea what an "Ssdi guest" is, but If you have Orbi on a closed network with no Internet access, which is unlikely, then you will need to manually update the firmware by downloading the ffirmware from Netgear onto a PC, logging into Orbi with a web browser, and uploading the file from your PC.
