chuahyenhua's avatar
chuahyenhua
Apprentice
May 04, 2017
Orbi automatic restart on new firmware! 1.9.1.12
This morning, the ORB updated its firmware automatically and restarted again.
I thought the system would usually prompt the user for update instead of auto update.
Is there a feature not to auto update the firmware but allow user to confirm before updating?
regards
  • Not at the moment and there is now way to turn off the auto update. I hope you have good luck with that version as some of us have had several issues.
    I was able to downgrade and block the update because I run my Orbi through and Asus Router that allowed me to block the download from happening.
  • What issues had u encountered for the new version? Somehow this really makes me somewhat regret getting this router
    • fbraz50's avatar
      fbraz50
      Apprentice
      My issue is outlined in that post but long story short the new firmware caused me packet loss. I would never lose connection but I would get spurts where no traffic was being passed to the Internet is in essence what I saw on this new version. Not totally sure that's the same issue but it might be related.
      This router combo is awesome and incredibly fast, when it works. I was all good up until this last firmware release which you can't block. What I did was block it at my router. I was able to do this because I use the Orbi's as just access points.
      • chuahyenhua's avatar
        chuahyenhua
        Apprentice
        well, i hope they can come out with a feature to allow user to upgrade or not.
        Suddenly this morning, all my apps could not work and i was wondering why.
        then i saw all my CCTV network camera went down and up and concluded its the router since it is also a DHCP server.
