siuengr
May 01, 2020Tutor
Orbi can't login to CBS
I cannot login to CBS all access through the Orbi.
I have tried
https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125
Tried using a different DNS server, no luck
I tried resetting my router. Still didn't work
I have Netgear Armor disabled.
It doesn't matter if I use a PC or Roku, I can't login. I've have tried multiple browswers, PCs, hardwire and wireless.
I connected directly to my modem and I can login fine. I also tried my old router and I can connect fine.
It only affects the login. If I connect to a different network to login, then I can switch back to the Orbi and still stream.
I can get to the login page, put in my credintials, click login, then nothing. It just sits there.
CBS is the only site I seem to be having issues with. Netflix works fine.
Sorry I am not a subscriber to CBS. Can you please confirm that on web browsers, you go to this web site:
https://www.cbs.com/cbs-all-access/signin/
Do you sign in with user/password, Facebook, or TV Provider credentials?
- siuengrTutor
That is the site I go to to log in. I can get to that page, but when I click continue, nothing happens.
I use a username and password.
Would also help to know:
- Specifically what modem (brand & model) the Orbi is connected to, and
- If Orbi is in "router" (the default) or Access Point (AP) mode.
Thanks
Thanks for the information. I also use Spectrum. would you happen to know the firmware release on the Orbi?
On the Orbi web interface, it is in the upper right corner.
