jbrown316's avatar
jbrown316
Apprentice
Aug 11, 2020
Orbi certificate issues on WiFi only
Hi all, just this morning I am having trouble using WiFi on my RBR50.  Wired devices seem to be working ok.  When I navigate to a website (i.e. Google) over WiFI, I am getting certificate/privacy errors.  I have verified that this happens on multiple WiFi devices.  This is also happening with Outlook 365 programs, I get a popup about certificate/privacy errors.  I rebooted the router and it seemed to fix the issue for a short time (<30 min) but then it started happening again.  The first incident was around noon EST.  Any suggestions?  I am running v2.5.1.16
I am logging conversation this over wired connection so that seems to be working ok.
  • I may have figured this out after acquiring a few more gray hairs.  I went into the advanced settings, security, access control from the Orbi UI and disabled, then re-enabled my laptop access.  It seems that doing that may have freed up all of the devices that were getting blocked.
    That is a super buggy and kludgy fix for a router this expensive.  Hopefully it will help someone else.
  • Looks like your not on the latest version. There aren't any release notes yet so maybe wait for that or try updating through orbi app.
    • jbrown316's avatar
      jbrown316
      Apprentice
      What is the latest version?  I checked the firmware update through the Orbi UI and it says that no new firmware is available...
        jbrown316
        Apprentice
