CB01's avatar
CB01
Tutor
Aug 20, 2019
Orbi connection inconsistent speed
I have 3 Orbi RBR50 setup in my house.  I am seeing issues with anyone connected to the satellite units seeing inconsistent speeds.  So I plugged a laptop into the main unit and one into the first satellite.  I ran a simple ping -t test.  The times are usually good, but every few packets there is a spike.  This is with both laptops plugged in to Ethernet ports.  I am running Firmware v2.3.5.30.
I have a default setup and wondering if there are some parameters I should change?  Or is there a way to detect signal strength between the boxes or anything else that might indicate why they seem to have issues with consistency.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • CB01's avatar
      CB01
      Tutor
      Home is around 3800 sq ft on two floors.  I have the main unit RBR50 and RBS50 that I was testing both on the main floor.  I would say they are 50ft plus between them.  Is 30ft the min or max suggested distance between?  The 3rd unit is an RBS50 is upstairs and is located between the other two.  The network map on the app shows both RBS connecting to the RBR50.  I will try putting them all on the same floor and see if that helps.
      2.4GHz is set to Auto
      5GHz is set to 48
      2 Neighbors have WiFi, but my signal strength is much higher.
      Beamforming and MIMO are both enabled already.
      I will check other settings are as mentioned after I try moving the units around.
      There are new units.  Initial configuration pulled down this firmware version.  No reset was done afterwards.  Should it be?
      • CB01's avatar
        CB01
        Tutor
        Didn't mention it, but I am using Spectrum as service provider.  But I am seeing issues with pinging two units that are hardwired into Orbi boxes.
        Spectrum Cable Modem is Hitron  E31N2v1.  It does not have WiFi enabled.
  • Retired_Member's avatar
    Retired_Member
    What were your 'speeds' BEFORE v2.3.5.30. ??
    • CB01's avatar
      CB01
      Tutor
      I had never used it with any older firmware.  This is a new setup.
      • CB01's avatar
        CB01
        Tutor
         I tried enabling the first list and disabling the second set.  No real performance change. The wired connection on the satellite is still terrible.  The app says the backhaul connection is good between the router and the satellite, but the ping time is still all over the place.  It will be good for a few pings and then jump to 500ms.  It just doesn't work.  I can attempt a factory reset and rebuild, but any other suggestions prior to returning the units and trying another product?
