BRC1971
Sep 16, 2020Aspirant
ORBI Connection to Xfinity keeps dropping
Hi Everyone,
I have had numerous and very frustrating issues over the past few weeks with connectivity between my Netgear Orbi and Xfinity Router. Connection between my Orbi Router and my Xfinity Modem continues to drop reapeatedly (3 to 4 times an hour for about 5 minutes each time). With working from home and kids doing remote learning...as you can imagine this is not ideal. I have the Orbi Modem in Access Point Mode.
I also have the xfinity modem (combo router) broadcasting Wifi signal due to the fact that I need to have some level of backup wifi connection from a connectivity perspective.
I am at wit's end...have signed up for Netgear's Gearhead support, which has not resolved any of the issues and have been on numerous calls with Comcast, which has not helped at all.
I have done numerous restart and resets of both the modem and router and it continues to have these issues. I have also looked through the posts on this site, but none of the posts or solutions have helped me.
Thank you in advance.
My home is about 4,500 square feet and have a large outdoor area (hence the two Outdoor Mesh Satellites).
My current set-up:
- Xfinity Modem
Model: CGM4331COM
XB-7 - RBR50v2 - Router (2nd Floor)
Firmware Version: V2.5.1.16 - RBS50 - Orbi Satellite - 1 (2nd Floor)
50 Feet from Router Linear - RBW30 - Orbi Satellite - 2 (1st Floor)
Firmware Version: V2.5.0.4
30 Feet From Orbi Satellite - 1 - RBS50 - Orbi Satellite - 3 (1st Floor)
Firmware Version: V 2.5.1.16
40 Feet from RBR50 Router - RBS50Y - Orbi Outdoor Satellite - 1
Firmware Version: V 2.3.5.32
40 Feet from Orbi Satellite - 3 (1st Floor) - RBS50Y - Orbi Outdoor Satellite - 1
50 Feet from Orbi Outdoor Satellite - 1
Advanced Wireless Settings (2.4Ghz)
This is Checked - Enable SSID Broadcast
This is Checked - Enable 20/40 MHz Coexistence
This is Checked - Enable WMM (Wi-Fi multimedia) settings
CTS/RTS Threshold (1-2347): 2347
Preamble Mode: Automatic
Transmit Power Control: 100%
Advanced Wireless Settings (5 Ghz)
This is Checked - CTS/RTS Threshold (1-2347) 2347
Transmit Power Control 100%
This is Checked - Enable Daisy-Chain Topology
This is Checked - Enable Implicit BEAMFORMING
This is Checked - Enable MU-MIMO
2.4 GHz - Channel 11
5 GHz - Channel 48
Be sure the wifi signals on the modem are disabled if your using the Orbi system.
Please mark your thread as solved so others will know.
Enjoy.
BRC1971 wrote:Thank you to everyone for your input.
Xfinity came out last night and provided me with a brand new XB-7 (replaced the existing XB-7 that I had) and that seemed to do the trick.
It surprises me that simply installing a new modem would have solved the problem, but I guess these devices do have glitches and do go bad...so far so good though.
Thanks again!
What happens if you disable wifi on the ISP router? Having both wifi signals online maybe causing problems and interferences with Orbi wifi. You really only need 1 wifi signal.
Whats the distanced between the modem and RBR?
Be sure to set a IP address reservation for the RBR in AP mode on the ISP router. .
Any Wifi Neighbors near by? If so, how many?- BRC1971Aspirant
Thank you for the response.
I have tried this and this has not improved the situation.
Whats the distanced between the modem and RBR? They are right next to each other
OK so just assign an IP Address when I log into the Xfinity Modem?
Any Wifi Neighbors near by? If so, how many? No there are not...- GMoGoody8Luminary
It is never recommended to place an Xfinity Modem/Router next to another router unless the Xfinity Modem/Router is in bridge mode.
This is because what isn't said is that depending on the services you are receiving from Comcast there are actually 6-10 SSIDs being broadcast from an Xfinity Router
1 - Your Private 2.4 LAN
2 - Your Private 5.0 LAN
3 - 2.4 open public hotspot
4 - 5.0 public hotspot
5 - 2.4 secure public hotspot
6 - 5.0 secure public hotspot
7 - 2.4 Xfinity Home Security if you subscribe
8 - 5.0 Xfinity Home Security if you subscribe
I only noticed this one time when running a WiFi sniffer in my house.
