JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
Apparently, my Orbi Router & Satellites auto-updated from 2.0.0.74 to 2.1.1.16 since I last looked at it on Monday. All my devices that are capable of 5Ghz are showing connected to 5Ghz, and all the devices are correctly showing their connection to either the router or a satellite. I haven't had any issues streaming Netflix or PSVue. I checked the debug.htm page on the router and both satellites, and they all show around 5 hours of uptime. I will check back on that later in the week, to see if they are rebooting, or if the upgrade actually happend 5 hours ago.
- ratickleApprentice
steelhorse83 wrote:Apparently, my Orbi Router & Satellites auto-updated from 2.0.0.74 to 2.1.1.16 since I last looked at it on Monday. All my devices that are capable of 5Ghz are showing connected to 5Ghz, and all the devices are correctly showing their connection to either the router or a satellite. I haven't had any issues streaming Netflix or PSVue. I checked the debug.htm page on the router and both satellites, and they all show around 5 hours of uptime. I will check back on that later in the week, to see if they are rebooting, or if the upgrade actually happend 5 hours ago.
I have a theory that firmware v2.1.1.12 is the version that has caused many people to have stability and functional problems. My theory also says that v2.1.1.16 indeed fix the problem caused by v2.1.1.12, but ONLY if a FACTORY RESET occured BEFORE the installation of v2.1.1.16. Since you went from v2.0.0.74 directly to v2.1.1.16 your system should be fine. If, and it's a big if, my theory about v2.1.1.12 is correct. Yes, report back in a day or two and let us know the system uptime and whether or not your satellite shows attached devices correctly.
- howiedubTutor
I don't think 2.1.1.12 has anything to do with it. I went from 2.0.0.74 straight to 2.1.1.16 and still had issues. Went back to 1.8.0.6 and it auto updated back to 2.1.1.16. Issues still persisted. Factory reset on 2.1.1.16 did not work. Back on 1.8.0.6 and everything is stable again. Have some bugs, but they are somethings I can live with as long as my connections don't drop and devices connect correctly. Disabled auto update through telnet, so hopefully that keeps it from updating again.
I'm starting to think it's hardware related. Seems like people who got their Orbis recently don't have the issues and those that have had it since the 1.* firmware days are the ones having issues. Just my 2 cents.
Well, I'm happy to report 28.5 hrs of uptime so far. No known issues yet. I think the only non-default setting I have is I deselected Daisy Chain after the 2.0 code came out. Other than that, it's mostly a stock configuration. I have 21 devices on the network.
- godspeedApprentice
Update:
This is my last attempt with Orbi. For the last few weeks, i have been using an Asus AC68 as the router, and the Orbi system in AP mode. Still getting reboots and dropped connections, no matter what settings i set, or how many times i factory reset.
This time, i am going to use the Orbi as a router. I factory reset both Router and Satellite, and setup all my port forwarding rules, changed DNS to openDNS, etc.
Will see if maybe the Asus router was causing issues with the Orbi in AP mode...
will update as the day goes on...
- Constant WiFi loss here. Router reboots. Affecting the entire network. In one day I have had probably 5 or 6 episodes of WiFi going down. At this point I’m thinking of abandoning it and going Eero Pro. I might give it a shot and see.
- miskaoneAspirant
I was having similar issues and it turned out that I had '$' in my network key (password). This stablized most of my issues. I will say I am on my 3rd set of Orbi's. I am not sure all my issues are resolved but at least I am not rebooting several times a day.
My Orbi and 2 satellites had all been previously updated manually, but still did an auto update to the new release without prompting, so the suggestion that this switches it off is not correct. I was left with a completely unusable system this morning. The information here seems to be the best advice to disable it: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
I rolled back to beta V2.0.1.2, which has been rock solid for a couple of months.
- RogerSCVirtuoso
NickC4555 wrote:My Orbi and 2 satellites had all been previously updated manually, but still did an auto update to the new release without prompting, so the suggestion that this switches it off is not correct. I was left with a completely unusable system this morning. The information here seems to be the best advice to disable it: https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
I wouldn't waste your time trying to block auto-update, unless you have a lot of time to burn. I've tried everything mentioned in this forum to block auto-update, including using dd-wrt on my R7800 (Orbi is in AP mode) and restricting access to "netgear.downloads.com" and "netgear.download.com" as well as all the telnet stuff on both the router and satellite. The dd-wrt dodge that I had high hopes for doesn't seem to have worked. When 2.1.1.16 went out, my Orbi said that there was new firmware available from Netgear, a bad sign for blocking auto-update. While I didn't wait to see if the Orbi could download it or not, I sort of assumed that the path that the Orbi uses to check for new firmware is the same path that it would use to download it. Once I find out what that path is, I can block it until Netgear changes it, but not there yet.
Sometimes it takes days for auto-update to catch up to you, but you can just assume that it will sooner or later *smile*.
- warrior101Aspirant
Updated R and S to latest firmware.
Orbi Network unable to connect via PC/iOS devices.
Performed Factory Reset.
Reconfigured Orbi Network.
Connect to Orbi Network via PC/iOS - **Checked OK**
Set Orbi-R to AP Mode (AT&T gateway/5268ac)
Reboots. Attempt to connect to Orbi Network via PC/iOS device - "Invalid password".
Everything has been fine since purchase (12/15) till updating to 2.1.1.16.
Is there anyway to roll-back firmware? Thanks
- netgearguyApprentice
Download the version you want from Netgear's web site and flash using the Manual option in the firmware update screen. Very simple.
Supposedly after a manual update the auto-update is disabled, but not sure that has been confirmed 100%.
- tomsliwowskiApprentice
Seeing the same weirdness with all wireless connections being reported as connected to the main Orbi router. Connected devices are 1 satellite and 23 clients, all but 2 show as connected to the RBR, the 2 that are not are PCs hardwired to the RBS. I wonder if this is for real or another bug. Also, daisy chain topology is disabled.
- njwebLuminary
My RBK 50 (3 unit system - router and 2 satellites) was upgradeded to 2.1.1.16 a few days ago (automatically). No issues so far. Have not tested all my devices yet but the ones we use are working fine.
Since that upgrade, I have used at least 3 laptops, 1 tablet, Android, iPhone and TiVO MoCA setup and Roku with it and things are working well.
I work remotely and not one disconnect yet from my home connection to my company virtual desktop (which requires a constant connection - if my router connection drops, my virtual desktop connection would get dropped too).
So far so good.
Settings (mostly default, using WPA2-AES security):
Daisy chaining is disabled.
I do have all of the following enabled:
BEAMFORMING MU-MIMO Enable Fast Roaming - cyberprashantLuminary
no problems here either with 2.1.1.6 wth the following settings:
CHECKED Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices CHECKED Enable MU-MIMO NOT CHECKED Enable Fast Roaming - njwebLuminary
njweb wrote:My RBK 50 (3 unit system - router and 2 satellites) was upgradeded to 2.1.1.16 a few days ago (automatically). No issues so far. Have not tested all my devices yet but the ones we use are working fine.
So far so good.
BEAMFORMING MU-MIMO Enable Fast Roaming Just to add:
I should perhaps have clarified - I saw a number of members posting about connection stability issues with 2.1.1.16. Thus, when I referred to no issues, I meant I was not observing any connectivity or other performance issues.
Connected Devices DISPLAY issue (does not impact performance?):
I see 21 devices connected (8 wired and 13 wireless). All 13 wireless devices show connected to the router which is not correct, so that issue indeed needs to be resolved. Luckily it appears to be a display issue only (correct me if anyone is seeing issues where all devices are actually connected to the router) and does NOT (appear to) impact throughput.
I'll have to run some signal strength and speedtests to confirm the devices are connected to the satellites.
I did run a test on my mobile phone a few days ago and it showed a signal strength consistent with being connected to the satellite (will need to double check though).
PS: I did not perform a factory reset (or NVRAM clear etc.).
the two new firmwares (v2.1.1.12 + v2.1.1.16) are very buggy !
it is a shame what for poor quality netgear delivers with such an expensive product.
the version 2.0.0.0.74, this is the only stable firmware version, downgrade router and satellit to this version (but this version has the security-leak KRACK)- sandsstlTutor
Fingers crossed.
Yesterday I updated to 2.1.1.16 and started having issues - lost the satellite, yada, yada, yada. Switched back to 2.0.0.74 and everything settled down.
This morning (≈ 14 hours ago), the system had auto-updated back to 2.1.1.16 and seemed to be reasonably stable...all devices were showing connected to the router, nothing to the satellite, and the Attached Devices page kept reloading every five seconds on Safari, but wifi speed was excellent and nothing appeared to be getting dropped.
Had some issues streaming with Sonos, so rebooted the system a couple of times through the day (still not sure that's resolved), but everthing seemed to continue to work.
So, this afternoon I decided to factory reset the satellite (saw someone had done that somewhere in this rather long topic) to see if the satellite would show up. Had a devil of a time getting the satellite to reconnect, but when it did the devices started showing up connected to the satellite. I had to forget the network on iPhones and iPad and reconnect, but it worked. That's been about five hours ago and, as far as I can tell, everthing seems to be stable and correct.
Attached Devices page reloading seems to be an issue with Safari, Chrome works fine.
Enable Daisy-Chain Topology is off
Beamforming, MU MIMO and Fast Roaming are on
- oldcakeAspirant
when i up to 2.1.1.16, my homekit 2.4g device was lost connection, when the 5G SSID was heidden and singal set to 25%, some device will back. if any setting change will make conection lost again.
i give up and back to 2.0.0.74
- Mayhugh1Apprentice
According to my uptime status indicators, I've had no stability problems with .16, and my speeds on all my wired and wireless devices look great, and so my complaint is relatively minor. I have two satellites with multiple devices wired to them, as well as seven wireless devices distributed among the router and satellites. Neither the Orbi app nor logging into the router shows either of the two devices that are wired to one of my satellites. The physical placement of my router and satellites is such that a star connection makes much more sense than a daisy chain connection, and so I don't have the 'use daisy chain option' checked. The backhaul status shows 'good' on both satellites. And so, I'm guessing this is a display bug in the firmware. I have mu-mimo and beamforming enabled, but otherwise am using default settings for the rest. One other detail that might help the developers is that the two satellite-wired computers that are not showing up happened to be sleeping when I decided to disable the daisy chaining (days after updating to .16) which rebooted the system. When the computers were awakened, they received IP addresses and had access to the internet, but neither showed up as connected to the internet.
- orbirickApprentice
With the knowledge that Orbi recently supported wired backhaul, I was in Costco about a week ago and saw the RBK53 system on sale for $70 off and impulsively decided to splurge on it.
I haven't had time to install it yet, but have already downloaded 2.1.1.12 and 2.1.1.16 for a manual upgrade when I do get around to cracking open the box.
However, reading the posts here, I find myself wondering if Orbi is worth the effort, but then I also realize that only the posters with problems tend to create posts. But man, the Orbi system certainly sounds like a problematic system with as many posting issues as there are.
Regardless, I intend to give it a try and plan to replace my existing RT-AC56U router and RT-N66U configured as an AP. I have ethernet run from my office to the den and living room where I plan to place the router and satellites and know to update the satellites before the router.
Other than that, is there anything special I should do to prep the Orbi system for installation? Are you guys separating the 2.4 and 5 GHz bands using separate SSIDs? It's been my experience with iPads, iPhones, Android phones, etc. that they tend to grab the first signal they get (typically the 2.4 band) and hang onto it for dear life.
I presently have separate SSIDs for the 2.4 GHz and 5 GHz bands so the 5 GHz devices can roam and stay with 5 GHz leaving the 2.4 GHz devices to do their own thing on the 2.4 GHz bands.
I have a couple of 8 port Gb switches, but am considering using my old primary router (RT-AC56U as a switch in the office (configured with wifi and DHCP disabled):
Internet/modem->RBR50 WAN port->RT-AC56U (now a switch)
AC56U->RBS50->4k TV
AC56U->printer
AC56U->PC
AC56U->8 port Gb switch on the other side of the house->RBS50, PS3, PS4, Fire TV, TV, etc.
I don't see a need right now for that 2nd 8 port Gb switch.
Once I have the new firmware upgraded, I should have wired backhaul and I expect the upstairs to get excellent wifi coverage with the 3 units positioned pretty much at either end of the house and a satellite near the center.
Any comments/suggestions?
- RogerSCVirtuoso
Trying an experiment here. I've flashed back to v2.0.0.76, and am waiting to see if I get auto-updated. In addition, I have the Orbi in AP mode, and R7800 in "wired-only" mode. And dd-wrt firmware on the R7800, with "netgear.downloads.com" and "netgear.download.com" blocked via dd-wrt "access restriction". Going to wait to see if the Orbi gets auto-updated...so far, after almost a day, I'm not getting the "there is newer firmware available" message yet, and things are stable and working well.
We'll see if Netgear can find me and auto-update my Orbi :-). Got a while to wait before I'll know.
- RogerSCVirtuoso
aaz wrote:
RogerSC wrote:Trying an experiment here. I've flashed back to v2.0.0.76, and am waiting to see if I get auto-updated. ....
Um, you won't get any auto updates since Negear has stopped auto updates over the holidays. You'll get it in the new year.
We'll see how long I can wait, since the latest was working fine for me as well *smile*. I'm not sure that just because I see the "there's newer firmware" message that the Orbi in AP mode will be able to download it with the "wired-only" main router access restrictions in place. Time will tell.
I confess I’m having 2nd thoughts about setting up the Orbi system. The issues here greatly concern me that I’ll have to nurse the system along to keep it running.
Im starting to reconsider deploying a trio of Ubiquiti USP-AC-LITEs in lieu of the Orbi system and continue to use my AC56U as a router only and disable WiFi on it.
I’d much rather have a reliable system that just works vs dealing with a temperamental system that lives on the bleeding edge to see a performance difference I may not even notice.
Am I reading too much into all these posts about firmware issues?
*UAP, not usp. Thanks autocorrect.
