jolo2's avatar
jolo2
Star
May 13, 2018
Orbi: I need to switch off wireless radios at night
I have an Orbi system, RBR50/RBK50.  I am increasingly aware of research that makes a good case for health risks for children from wifi systems, even if they operate within legal limits (e.g. https://www.youtube.com/watch?v=F0NEaPTu9oI).  So I would like my wifi to work on a schedule, switching off the radios at night to keep a safe environment while the family is asleep.
I don't believe this is possible using the Orbi settings.  Is that true?  If not, please can a system for this be enabled to ensure that concerned parents can benefit from this technology as safely as possible.
  • FURRYe38's avatar
    You can reduce the power out put from the radios...
    • jolo2's avatar
      jolo2
      Star
      Thanks, but can I do that on a schedule?  It needs to work well when it's in use.
      • FURRYe38's avatar
        Unfortunately theres no scheduling of wifi on these systems. So you can either lower the power or disable the radios however it would have to be done manually.
  • what makes it "safe" at during the day, but not at night?
    • JoeCymru's avatar
      JoeCymru
      Virtuoso
      I am sorry, and with all due respect, with all the click bait articles and other wifi danger scenarios that have been floating about, some reason and science must be introduced into the debate before we all toss our phones and routers into the garbage and go back to paper and landlines.The really bad radiation is ionizing. Radio and microwave radiation is not. Those wavelengths are longer than even visible light. Microwaves in your oven are 700 to 1200 watts. Even without shielding you still would not feel it unless you crawled in, and the danger is the water molecules heating up, not ionizing radiation destroying tissue or DNA. Your router puts out perhaps 1 watt in a dispersed cloud. Also, the quantity or intensity of linear-wave radiation is directly inverse to the distance the observing/affected body is from the source of the radiation, so the power drops off quickly with distance.
      Your router puts out non-ionizing, low frequency radiation (lower than infrared or visible light) in extremely low absorbtion power. To be afraid of this, you also need to be terrified of visible light. The next higher frequency of light above visible is ultra violet, which is the very beginning of where there could be long term cumulative damage due to some minor ionization in light skinned people. There are magnitudes of danger more in going outside without slathering yourself with sunscreen if you are light skinned, than owning an Orbi and leaving it on.
      • jolo2's avatar
        jolo2
        Star
        Thanks for your detailed and polite response.  I also write with respect and appreciation for what you've said.  That being said, I don't find your comparisons  helpful.  The word "radiation" per se is not a concern to me and I don't think that RF is the same as ionising radiation, of course!  As regards sunlight, the fact that over-exposure is dangerous is a well documented and serious risk, as you say, but it is a fallacy to move from that to the claim that levels of exposure to RF can be ignored.  The issues are different.
        There are unanswered questions emerging when it comes to wifi becase of the permanent exposure to levels of RF that, while low, are orders of magnitude higher than would have been the case previously.  There have always been concerns about the effects of RF and microwave radiation stretching way back before wifi.  This was clear to me as a radio amateur using mobile technology in the VHF and UHF wavebands as far back as the 1980s.  The power output of that equipment was much higher, but it was not present everywhere or all the time.
        Now that these issues about wifi are mainstream they are, of course, a happy hunting ground for the uninformed neurotic and so I share frustration about that.  That is not the point, however.  There seems to be a paucity of research in this area and also vested commercial interests, so at least some concern is warranted.  As in other areas of technology, enthusiasm about what new technology can do means that adoption outstrips responsible use and so there is the possibility of living to regret this.  For example, while UK government advice for mobile phones is that children should not use them unless absolutely necessary and then only for short periods, this is largely unknown and ignored.  It may be that we find in a generation that there are no long-term ills associated with this technology.  But at this stage we don't know and there is evidence emerging that the picture may not be entirely rosy. If you know about this research then do let me know because I am only just beginning to hear about it.
        In the meantime, parents want to look after their children and in the absence of clear information may want to limit their overall exposure by not having the wifi switched on at night.  That is not unreasonable and it is a very simple and inexpensive thing for manufacturers to install in their products until such time as we have not a lack of evidence of harm but positive evidence of safety.
  • FURRYe38's avatar
    If your wanting more information about Wifi, I would head over to the wi-fi.org and or fcc.gov to see if they have more information regarding wifi and safety regulations since they are the ones that govern wifi Mfrs and the FCC governs wifi usage here in the USA.
    Good Luck.
  • Have you considered an electrical outlet timer?
    • Regarding the electrical timers suggested above.....
      This is what I have done as well. However, these routers and satellites should have the capability to enable/disable wireless radios at times as desired by the end user. This feature set (as well as many others) is avaible on numerous other routers / WAPs at substantially lower price points.
      Orbi stated this funtonality will be implemented in a future firmware update.   Monthes later Orbi & STILL WAITING.... I currently don't recommend these because of limited customization and unfillfilled promises. The performance as a dumb box of hardware that delivers high speeds and relibility is great, but the price should command customization at least as much as competitors at a fraction of the price.
      • tsig's avatar
        tsig
        Luminary
        Stalliono
        So you bought the product fully aware of its "limitations", and are now complaining about those "limitations"?
  • FURRYe38's avatar
    Also users need to understand that if NG says it might add a feature, it's NOT going to be added over night and will take time for them to develop and test using there own time frames before it gets released. Could be months or even years before something is seen. There is alot that goes in to development of FW and it's features. Not all of it is done or comes from NG. There are 3rd party vendors and chipset makers that are involved as well.
    Also pray that marketing doesn't get involed as they are known to push changed to the next HW version which would not include current HW versions out in the wild.
    Complaining about in the forums dones nothing and doesn't speed up NG work on things. Engineers don't even look at forums much anything else. Thats not there priority. If they looked at the forums and everyones complaints, they'd never get any work done.
    You can post your request here as this seems to be one central point that NG seems to look at for users requested features:
    https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
    In mean time, live with the product or find something else that works for you.
    • Stalliono's avatar
      Stalliono
      Guide
      FURRYe38, thank you for the reply. Based on your previous posts, you have good insight and try to help persons. I appreciate that.
      Thank you for the info on the NG ideaexchange board. I will inquire about their progress with these features in upcoming updates.
      "Complaining about in the forums dones nothing and doesn't speed up NG work on things."
      Furry I totally agree. My justification for making said statement was not to influence NG or its engineer's seeming lethargy on implementing promised improvements. I should have been more clear. However, my intention was 1) to merely state that the company has not fulfilled its pledge to add said functionality and 2) inform other purchasers / potential purchasers of limitations.
       "In mean time, live with the product or find something else that works for you."
      That is what i've already done with the electrical timers. Happy with Orbi performance, little disapponted with current features.
      Cheers.
      • FURRYe38's avatar
        I think we all can agree that theres features that need improvement. As time goes one, hopefully NG will make those changes and will add more features to the system. I believe if people keep post there in the idea forum and contacting NG and bugging them about it, may see some results. Only time will tell. Again, the cycle only last for a while, then of course, NG may introduce new HW which may have these changes and which older HW may not get. Just letting you know.
        Cheers.
  • I'd like to upvote this. My past routers have all had this feature. There's no reason for this top of the line router to not have it.
