hosregla
Dec 04, 2016Aspirant
wired router and 5 switches
Hello guys how is the best wired. i have ffth with AMPER eg-663 WIRED: G01 EG-663 ---> RACKG SWG (.203) G01 40m G02 EG-663 ---> RACKAB SW (.200) G01 38 m ------> SWB (x.201...
- Jan 04, 2017
It seems that your goal in setting up LACP is to improve the read/write speeds between PCs, am I right? It seems your concern is similar to this forum link I found online. Kindly access and read it.
Doing an iPerf test would help. Here are the links I found online that you could use as a guide to perform an iPerf test.
What is iPerf and how is it used?
Basic Network Testing with iPerf
DaneA
NETGEAR Community Team
hosregla
Dec 26, 2016Aspirant
Hi Hosregla,
I will close the case, when trying to change the LAG mode to the one recommended above.
And when you try to connect all SWITCHES to A.
Thank you.
DaneA
Dec 26, 2016NETGEAR Employee Retired
Does it mean that everything is working fine especially the LAG setup?
DaneA
- hosreglaJan 03, 2017Aspirant
Sorry for the delay, I have not been to work in the last 15 days.
i have just change to LACP, this night reboot Switches. SW A and SW B. I will test traficc with same program.(totusoft.com/ LAN SPEED TEST)
and after, i will wired all swiches B,C,D,E,G to A (directly) and I will check if there is any difference with the current scheme.
- hosreglaJan 04, 2017Aspirant
i have the same result with LACP without LACP.
- DaneAJan 04, 2017NETGEAR Employee Retired
DaneA
Obviously if NETGEAR FORUM says that I put LACP, instead of STATIC, I put LACP.
I completely understand that a test of velocity measurement, between two points, is very simple, and that there must be deeper tests.
Thnks by your knowledgebase!!!!
