Samtwo's avatar
Samtwo
Orbi mesh systems
I have a Netgear AC1900 WiFi cable router-modem. My ISP is Spectrum.
I need to add a mesh WiFi system; the Orbi systems seem like the best choice since they'll be compatible with the existing gear.
So I'll apreciate help in clarifying some points -
1) Do I need to replace the AC1900 or is it possible for the Orbi to plug into the modem?
2) The coverage is for a ~2,500 sqf home plus outdoors. Should I get a 2 or 3 component system?
3) Should I go with a WiFi 6 system or is it an overkill?
Thanks, Sam
  • FURRYe38's avatar
    If your modem has a built in router and wifi already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    You can still use your current modem, just configure it to one of the suggestions above. If it's working well for you, I would try option#3 first. The NG cable modem/router can be bridged for option#1.
    Look for what may work best for you for you size of home.
    https://www.netgear.com/orbi/default.aspx
    https://www.netgear.com/orbi/wifi-systems.aspx
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    If you have devices that support AX mode then maybe, if not, then Orbi AC will be good for you unless you just want to future proof your house hold.
  • FURRYe38's avatar
    Any progress on this?
    Thanks, Sam
    • Samtwo's avatar
      Samtwo
      Thanks for the help. Yes, there's progress - my Netgear cable router-modem can be set in bridge mode.I have ordered the Orbi RBK50V, a 2 pack with Alexa built-in. I may need a second satellite; this will bedetermined after the 2 pack is installed.
      This sytem is now at a discount so grab it if you need something like that.
      Sam
      • FURRYe38's avatar
        Sounds good. Review the placement suggestion when yout get your system in and start setting it up.
