tummie93's avatar
Feb 24, 2020
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic
  1. Call Centurylink for your pppoe username and password and vlan number which is (201)
  2. Have laptop and ethernet wire
  3. Log on to orbilogin.net
  4. On Basic tab
  5. Make sure you have to the most updated firmware on your router and satellite
  6. Once you determine your software is up to date
  7. Enter your internet service provider pppoe and password
  8. Go into your Advanced tab
  9. Advance setting change to vlan to 201
  10. Follow orbi instruction on set up
  11. Your internet should connect
  • FURRYe38's avatar
    Great write up. Thanks for posing. Hope this helps those with CL Fiber services.
    :smileywink:
  • Retired_Member's avatar
    Retired_Member
    4. On Basic tab
    I wouldn't worry about step#5
    Once 'connected' to the Internet, the Orbi/Sat should check whether a update is required and the push will be automatically.  But even if someone where to follow this sequence and get to #5 and discover the FW is outdated (which may be the case coming out of the box), how do they update it if the Internet connection is at step#11??
    • tummie93's avatar
      tummie93
      Tutor
      That's not the case for me.  There was no prompt to update the firmware.  I couldn't connect onto the orbi wifi and kept running into issue.  I had to restart the whole process.  Had to do step 1 and all the way to step 11 before the Orbi router connected.  To update the firmware I was still connected to my old CL router. Once the firmware was updated, Vlan showed up in the Orbilogin.net therefore i was able to log on and change the Vlan to 201 or else nothing will work.
      • tummie93's avatar
        tummie93
        Tutor
        I prob missed a step...
        If firmware is not up to date.  Need to connect back to CL router for wifi access to update firmware.
  • I followed the instructions above how it wont connect to the internet.  I have the PPPoE credentials from Centurylink and inputed the information. I also did the VLAN 201 tagging.
    Any thoughts?
    • cboglio's avatar
      cboglio
      I added a second screenshot
    • tummie93's avatar
      tummie93
      Tutor
      U sure the router and both satellite software is updated?
      • cboglio's avatar
        cboglio
        Yes. I checked in both the Orbi app and online router config page.
        V 2.5.1.8
        Im at a loss.
  • If you don't have a laptop and just an iPhone, can you do this set up
    • FURRYe38's avatar
      You can set up any Orbi wifi system using the Orbi app.
