Noiprocs's avatar
Aug 07, 2019
ORBI RB 50 - Sign in , your connection to this site is not private, and he asks Usename and paswoord
I installed the Orbi RBR50 and 1 satellite: It works correctly But
Since I instaleld this, I can not visit all sites, it blocks on some sites, on my pc but also on my Ipad. If I switch to another network, I can go on all sites.
the message is
Sign in
http://click...
Your connection to the site is not private
 Username: (I have to fil it)
Password : ( I have to fill it)
Sign in or Cancel
thanks for your support,
I am not a specialist ;-)
  • FURRYe38's avatar
    Is the Orbi system operating in Router or Access Point mode?
    What browser are you using?
    This a wired PC or wireless device?
    Happens with all devices when visiting web sites?
    • Noiprocs's avatar
      Noiprocs
      Tutor
      Hello
      Firts thanks for your raection : as I mentionned, I am not a specialist
      Firmware version is 2.3.1.60, I updated when I installed
      • PC and Tablet are working with WIFI
      • Sotware I used is Chrome on PC
      • Chrome and Quant on Ipad
      it happens not on all site, but it happens on a lot of site as Autoscout,...
      it is also new, I had this never before and we are "connected" since 20 years ;-)
      We are in Belgium and I connect the Orbi to the Router we have from the telecom company (Proximus).
      I use teh Orbi as Router and the satelliet as accespoint
      The router from the telecom company ( Proximus)
      B-Box 3
      • Mémoire flash 128 MB
      • Mémoire RAM 256 MB
      • Processeur : 400 Mhz Dual Core
      • Port DSL : 1 port RJ11
      • Interface LAN : 4 port RJ45 1 GBps
      • Interface WAN : 1 port RJ45 1 GBps
      • Wi-Fi : Dual band : 02.11b/g/n 2.4 GHz et WiFi 02.11a/n 5 GHz |
      • Port USB : 2 (actif
      • Norme IP : IPv4 et IPv6
      I am not sure I fully answer to your question, sorry
      Guy
  • FURRYe38's avatar
