ShreeMoorthy
Apr 12, 2021Star
Orbi RBK-53 AC3000 Mesh system - Internet access interruptions after latest update V2.7.2.104
Till I updated to the latest firmware V2.7.2.104, everything was OK with using ACL. Now, randomly ACL will stop all internet access (errors like certificate cannot be trusted, etc). The 1st time, I t...
Apr 12, 2021Guru - Experienced User
Perform a full factory reset on both router and satellite(s) then set up from scratch.
vajim
Apr 13, 2021Master
FURRYe38 wrote:Perform a full factory reset on both router and satellite(s) then set up from scratch.
Why does your response not mention V2.7.2.104?
- plemansApr 13, 2021Guru - Experienced User
vajim wrote:Why does your response not mention V2.7.2.104?
I believe it was already mentioned. 2nd post?
- vajimApr 13, 2021Master
true...but for some reason our friend FURRYe38 avoids it
- BoilerPlateApr 13, 2021Apprentice
Why would it need to be brought it if the version was already mentioned? Clearly wasn't needed. But you feel that if it doesn't work for some users it must not work for EVERYONE? But it's ok for you to mention that your version of FW work when historcally it was a major failure for everyone as well. If it had worked everyone would still be using it. Why do you keep badgering users here in the forums with your zero skill set? Clearly stupidity and ingnorance run rampant with you. Stop badgering people about how they help others. This is NOT your forum. If you don't like how users are helping others, go somewhere else. You don't get to tell people how to help others. So what if some people have working systems. Let them help others and stop trolling the forum. Go get a life. Nobody here listens to you. You waste your own time and others badgering people who want help other and user who want to find help.
Stop playing the victim as you instigate everything you get back. You start all this crap. STOP IT!!
vajim's lack of knowledge and experience, your mileage may vary. >vajim. User beware. :smileysad:
Historical posts prove it:
https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/m-p/2055212
https://community.netgear.com/t5/Orbi/Orbi-RSR50-firmware-2-5-1-16/m-p/1903734/highlight/true#M90556
https://community.netgear.com/t5/Orbi/Problems-with-new-Orbi-RBK53-setup/m-p/1876257#M85028
https://community.netgear.com/t5/Orbi/Constant-VPN-reconnecting-since-upgrading-to-firmware-V2-5-1-8/td-p/1879290/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Netgear-drops-the-ball-again-RBR50-on-FW2-5-1-8/td-p/1876302/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-was-working-amp-changed-modem-now-not-working/m-p/1887710#M87429
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speeds-Drop/td-p/1891090/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/dropped-bandwidth-on-Orbi-RBR50-with-cm1000-modem/m-p/1901910#M90201
https://community.netgear.com/t5/Orbi/Orbi-RBR50-bricked-during-update-to-2-3-5-30/m-p/1897073/highlight/false#M89235Sad that he has to spread false and inaccurate information and badger and troll others that are just providing help to others. Must have a sad life.
:smileysad:NG PLEASE BAN HIM for cyring out loud.
