Cnacopy's avatar
Cnacopy
Orbi RBK23 Started Blocking My Coporate Web site
I've had the Orbi RBK23-100NAS since January 2nd. The other day as I was working on my company's web site (https), Orbi decided to just prevent me from viewing the site anymore. If I connect directly to my cable moden (no wi-fi on the cable modem), I have no issue, so it's definitely Orbi causing the problem. I updated the firmware, rebooted, unplugged all connections and restarted, added https domains to always allow access under the Block Services tab of orbilogin.com. Nothing works and I see this is a consistent problem with Orbi and Netgear is aware but hasn't fixed it. I did not activitate Armor or Circle on it so there's no domain monitoring or blocking software. Appreciate any suggestions as I'm at the point I'm ready to throw out Orbi!
  • plemans's avatar
    Have you tried using a different dns server instead of the one from the isp?
    try googles at 8.8.8.8 or 8.8.4.4
    or cloudfare at 1.1.1.1
    • plemans's avatar
      What modem are you using?
      are you using ipv4 or ipv6
      • Cnacopy's avatar
        Cnacopy
        It's an Arris TM822 which has both IPv4 and IPv6 modes.
    • Cnacopy's avatar
      Cnacopy
      Thanks for the suggestion but it still doesn't work changing DNS.
  • FURRYe38's avatar
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Cnacopy's avatar
      Cnacopy
      Thanks. Appreciate the tips. I'm on V2.5.1.16. I updated to the latest firmware after the problem started. Just tried everything you mentioned, including resetting, and still can't access the website. I get the error message -  The connection has timed out. The server is taking too long to respond. But there's nothing wrong with the website.
      • FURRYe38's avatar
        Someting to contact the web master of the web site to see whats going on.
  • Thanks for everyone's help but nothing has worked to fix the problem. So now it looks like the only option based on the way Netgear runs support is to pay $89 to GearHead in order to try and resolve this. There's no way of connecting support otherwise. Looks like I'll be tossing Orbi out and leaving Netgear instead.
