Racie23
May 10, 2018Aspirant
Orbi RBK30 dropping internet connection daily
Orbi drops internet connection daily. Need help fixing this issue. For the first few months of ownership it only happened a few times but we should’ve heeded the warning because it now drops the internet connection daily and has to be reset manually for the connection to start again. Please let me know if any fixes exist. Feel like we made a big mistake on this purchase. Need help please.
Whats the Mfr and model # of the ISP modem the RBK is connected too? Any built in router here by chance?
Do you still have access to the routers web page when this happens?
Both wired and wireless?
Any wifi neighbors near by? If so, how many?
Try using manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try disabling MIMO, Daisy Chain, Fast Roaming and IPv6.
- Racie23AspirantModem is a Motorola surfboard. Don’t know the model # but it does not have a built in router.
No access to the router’s webpage when this happens.
We haven’t tried wired but know it is all wireless.
We do have WiFi neighbors. 5 Networks show up in range of our house.
We will try your suggestions. Thank you!- FURRYe38Guru - Experienced User
Let us know how it goes...
Whats the Mfr and model # of the ISP modem the RBK is connected too.
Any wireless neighbors hear by?
May not be a NG problem until you find out whats really wrong and the real causes of your problems.
What channels are your neighbors using?
What channels are you now using on your router?
How big is your home? SqFt?
Distances between Orbi and satellite?
- Racie23AspirantMy neighbors are using 2, 4 and 11.
We are on channel 6.
1500SF home.
40’ between Orbi and Satellite.
I had to reset 7 times yesterday and 6 so far today. So frustrating.
- sk_ishAspirant
Having the same problem. Speeds are great for about a day and then it goes down. Can't access the web portal or find the router using the app and have to restart the router manually.
not a channel issue, no conflicting networks, modem has a gateway but is in bridge mode, latest firmware installed but was having the same issue with the previous firmware. This is incredibly frustrating, we purchased the Orbi to get better coverage throughout the house and it's great when it's working, but these daily disconnects completely override any benefits it had
