GamerXYZ
Sep 04, 2017Tutor
Orbi RBK50 SSID not in list
I'm trying to set up the Orbi RBK50 system (so, to be clear: it's new and straight out of the box). The first 2 steps in the quick-start guide went without a hitch: I end up with a blue light. But then step 3: it tells me to connect to the Orbi system, but its SSID (ORBI25, according to the information on the Orbi router) does not show up in the network list (nothing new shows up at all). I've tried all computers, this includes 2 OS (Windows 7 and Windows 10). I've also tried manually connecting by entering the SSID myself, as well as the correct password of course, but nothing.
Obviously the next step was to connect a computer (laptop) with an ethernet cable to the Orbi system (tried the Orbi satellite first, and when that failed I also tried the Orbi router), completing step 3 that way, and hoping it will then properly show up in the network list. I'm seemingly connected through the Orbi system that way, which orbilogin.net also shows as it doesn't come up with the "You are not connected to your Orbi's WiFi network"-message but instead comes with a login window, but I can't login with "admin" as name and "password" as password (without the quotation marks of course), despite the quick-start guide telling me this is the name and password for orbilogin.net.
Hopefully someone can help me figure out what I'm doing wrong: help is very much appreciated.
Well, if you can reach the login screen but cannot log into the router using the default username/password then something is very wrong. If done properly, the reset will restore the default login credentials. You must hold down the reset button for a long time until the power LED starts blinking amber for the reset to be effective.
- GamerXYZTutor
I have something to add to my post: it's not entirely true that nothing new shows up in my network list, a "hidden network" shows up when the Orbi's connected. However, connecting through it using the Orbi's SSID and password doesn't work. Some research has shown me it's apparantly what the Orbi Router uses to connect with the Orbi Satellite, so at least there's proof it's communicating (but then again, the blue light also does this).
Also, from trying out today, I've found something peculiar: when the Orbi's connected, the digital TV signal becomes absolute rubbish. Artifacts everywhere, sound working only like once a second, etcetera. Disconnected the TV signal to see if maybe the Orbi's SSID doesn't show up due to a conflict, but that doesn't seem to be the case. - st_shawMaster
Try resetting the Orbi units using a paperclip inserted into the reset hole on the back.
- GamerXYZTutor
Thanks for the reply. Unfortunately, the reset button didn't solve the problem
- st_shawMaster
