jkcrwdr's avatar
jkcrwdr
Orbi RBK50 w/ Powerline
Hi all,
I have recently (in the last week) upgraded my family to the Orbi 50 system and it works great. To cut a long story short; we have an office/study at the bottom of the garden where the signal does not reach. My Father has just purchased a wired powerline kit for use in the garden building (electricity runs on the same circuit as the house), but for some reason I get no internet connection when one PL is hooked up to the Orbi router and the second PL is to my Macbook.
Is there any settings I need to enable to make things work, or are Powerlines & Orbi not compatible? I have struggled to find similar circumstances along with actual help, so I have taken the plunge here.
Thanks for reading and any help is appreciated!
  • FURRYe38's avatar
    Does the PL work in the same room? I would test this out in the same room first.
    PLs can be problematic...
    How about adding another Satellite to near this office?
    • jkcrwdr's avatar
      jkcrwdr
      My parents don't really want to shell out more money for an additional satellite.
      I have tried two kinds of PL, one wireless (through a seperate SSID) and the most recent wired, but both don't seem to be chucking me any Internet access. I was wondering (hoping) there was an advanced setting I needed to enable to allow to make this possible, but I guess I'm out of luck in that regard?
      • FURRYe38's avatar
        Did you try both PLs in the same room to verify same room circuit connetion?
        I presume if this also fails, there isn't any configuration I know of.
        Might disable Daisy Chain and see if this helps any.
