DSC829
Mar 10, 2021Aspirant
Orbi RBR-50 - unstable connection and slow speeds
I have an RBR 50 and 2 RBS50 satellites and 1 RBS50Y outside. The router is connected through a Gigaclear router in bridge mode through a Vigor Draytek firewall. 1 RBS50 is connected via Ethernet (n...
- Mar 13, 2021
So in the end i did another factory reset, rolled them all back in the firmware and then did the updates again and reconnected all the satellites one a time. After a lot of playing around it seems to have stabilised but we'll see.
Ha_Ku_Na
Mar 10, 2021Luminary
I suggest to update all RBS manually to the latest FW.
-> Download the FW from the support webpage
Then connect to one of the RBS's via a browser:
http://ip-of-the-rbs
You find the ip's of the satellites in the webadmin GUI (http://orbilogin.com)
After the update, power off the RBS for 1-2 minutes, then let them start and connect (one by one, until they are connected successfully).
vajim
Mar 10, 2021Master
Here's another for your files
Ha_Ku_Na wrote:I suggest to update all RBS manually to the latest FW.
DISCLAIMER:
please ignore posts from user vajim.
He is just acting like a bad troll here in the forum.
Unfortunately the moderators are not taking any actions against that.
the truth hurts
- BoilerPlateMar 10, 2021Apprentice
Vajim's lack of knowledge and experience, your help and support mileage may vary.
Historical "files" posts prove it:
https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/m-p/2055212
https://community.netgear.com/t5/Orbi/Orbi-RSR50-firmware-2-5-1-16/m-p/1903734/highlight/true#M90556
https://community.netgear.com/t5/Orbi/Problems-with-new-Orbi-RBK53-setup/m-p/1876257#M85028
https://community.netgear.com/t5/Orbi/Constant-VPN-reconnecting-since-upgrading-to-firmware-V2-5-1-8/td-p/1879290/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Netgear-drops-the-ball-again-RBR50-on-FW2-5-1-8/td-p/1876302/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-was-working-amp-changed-modem-now-not-working/m-p/1887710#M87429
https://community.netgear.com/t5/Orbi/Orbi-RBK50-Speeds-Drop/td-p/1891090/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/dropped-bandwidth-on-Orbi-RBR50-with-cm1000-modem/m-p/1901910#M90201
https://community.netgear.com/t5/Orbi/Orbi-RBR50-bricked-during-update-to-2-3-5-30/m-p/1897073/highlight/false#M89235Sad that he has to spread false and inaccurate, unhelpful information and badger, troll, that are just providing help to others. It's confusing to users and discouraging for those just looking for help and good information.
Must have a sad life.
- vajimMar 10, 2021Master
more for your files
BoilerPlate wrote:Vajim's lack of knowledge and experience, your help and support mileage may vary.
