skymetal
Feb 15, 2020Aspirant
Orbi RBR20
I switched internet providers and purchased a Nighthawk X6S AC4000 wifi router. I also previously had the Orbi RBR20. The orbi is not connecting or meshing with my new nighthawk. Can anyone tell me why? I have tried uninstalling the app and doing a fresh reconnect.
- I ended up calling customer service and had to purchase a plan to get help. Had to reset the orbi router and do the manual setup on orbionline.net. got it to work
X6s isn't a model. neither is ac4000, its a speed. which model is it?
Are you going modem-----AC4000------orbi?
If so, do you have the orbi in AP (access point) mode?
Otherwise you're running 2 routers in router mode on your network and you end up with a double nat which can cause your issue.
Perhaps this is it: https://www.amazon.com/NETGEAR-Nighthawk-Tri-band-Ethernet-Compatible/dp/B072LZZZXB
Certainly a combination router/WiFi.
- skymetalAspirantI ended up calling customer service and had to purchase a plan to get help. Had to reset the orbi router and do the manual setup on orbionline.net. got it to work
Any progress on this?
skymetal wrote:I switched internet providers and purchased a Nighthawk X6S AC4000 wifi router. I also previously had the Orbi RBR20. The orbi is not connecting or meshing with my new nighthawk. Can anyone tell me why? I have tried uninstalling the app and doing a fresh reconnect.
